1Back to top Go down   which DeoxIT? Empty which DeoxIT? Mon Feb 20, 2012 9:05 am
Now that I'm removing the tank I may as well give the contacts the once over. The problem is Caig don't sent Aerosols overseas by post and I can't find an Irish supplier. There are little tubes of stuff available from fleabay are these as good and which one(s) to get?
88KE
2Back to top Go down   which DeoxIT? Empty Re: which DeoxIT? Mon Feb 20, 2012 9:22 am
Some of the guys here get it from the shops that sell musical instruments. I believe it is used to clean the plug terminals on music keyboards etc.
The little packs do work the same but don't last long, they are very small.
3Back to top Go down   which DeoxIT? Empty Re: which DeoxIT? Mon Feb 20, 2012 10:34 am
which DeoxIT? Produc10
this is the version i use 88 ...i guess they should ship it ...aerosols are verry wastefull
4Back to top Go down   which DeoxIT? Empty Re: which DeoxIT? Mon Feb 20, 2012 12:33 pm
I reckon so Charlie those little brushes would be handy too. An aerosol of D5 would work out at €25 if I could get their european agent to post it. A tad expensive!
which DeoxIT? Ir-log1188....May contain nuts!which DeoxIT? Ir-log11
K75RTP - 1994
5Back to top Go down   which DeoxIT? Empty Re: which DeoxIT? Mon Feb 20, 2012 2:58 pm
You should be able to pick up an equivalent product to Deoxit from RS Components in the UK. Try this link:
Contact Treatment Products
The Electrolube EREML200F, EML Contact Lubricant (better) or Kontakt Chemie "Kontakt 60" (best) would be suitable substitutes at a resonable cost to you.
6Back to top Go down   which DeoxIT? Empty Re: which DeoxIT? Mon Feb 20, 2012 7:16 pm
http://store.caig.com/s.nl/SS.112/ctype.SS/id.17459/.f?category=112&sc=15
It says "no longer available" on the tab, but it does that whichever int. distr.
is choosed from the list..........a phone call gives you the answer.
7Back to top Go down   which DeoxIT? Empty Re: which DeoxIT? Fri Feb 24, 2012 7:03 pm
So far I have not found an equivalent to DeoxIT I have tried Electrolube and many others and they just don't work like DeoxIT.
A call to Caig should enable you to get the nearest agent that stocks the D5 and S5 aerosols. I found in my case it was a tool shop that specialises in the electronics trade. The two bottles shown above was what I use when giving contacts an initial clean and finish up with the D5 let that dry and then use the S5.
8Back to top Go down   which DeoxIT? Empty Re: which DeoxIT? Fri Feb 24, 2012 7:10 pm
have you tried jaycar.uk ?
9Back to top Go down   which DeoxIT? Empty Re: which DeoxIT? Mon Mar 12, 2012 4:55 pm
Well, I've sucumbed to the high pressure
'Forum Deoxit Sales Team'
and bought a bottle of D5. (From Russ Andrews).
So now all my electrical problems that I haven't got will all be fixed before they appear....... which DeoxIT? 723598
Actually, my 1975 Leak 2000 tuner/amp suffers from noisy switches and pots so that will be a good test.
Cheers, Paul.
10Back to top Go down   which DeoxIT? Empty Re: which DeoxIT? Mon Mar 12, 2012 5:09 pm
switches yes .... carefull on the pots paul there are other products for that ...just a heads up
11Back to top Go down   which DeoxIT? Empty Re: which DeoxIT? Mon Mar 12, 2012 7:26 pm
Thanks, Charlie, perhaps I'll get another mortgage for some faderlube... Rolling Eyes
