1 Play in Speedometer Needle Mon Feb 20, 2012 1:14 am
FreebasserSF
I just took apart my speedometer and I noticed that there is up and down play on the shaft which spins the needle to indicate your speed. What is weird is that when the instrument cluster is lying down with the shaft perpendicular to the table the needle sinks down about 0.5 mm or so and when I spin the needle there is a lot of resistance and the needle does not return to the zero position. When the instrument cluster is upright with the shaft parallel to the table there is no resistance and the needle moves freely. Has anyone else noticed this play? I found that I have continuity everywhere it seems there should be, yet my speedometer was not working (nor the odometer).
On my bike i have my instrument cluster angled at maybe 20 degrees from horizontal ground, which would cause the resistance I just described. So it seems to me that if there is always resistance in excess of the magnetic torque produced by the magnet, the needle wouldn't spin and, therefore, the bike wouldn't register any miles. Does anyone know if this play is normal and if it's not is there a remedy? I don't want to gut the speedometer until someone says I should.
