1Back to top Go down   spline job Empty spline job Tue Sep 20, 2011 7:33 pm
mikeeeee
simple trick to do a spline job with ease without removing the whole ass end.
instead of removing the swing arm and rear wheel, leave them on.
get 4 extra long 8 by 150 mm bolts.
remove all the bellhousing bolts and screw in the long ones.
slide the whole ass end back on the long bolts and the transmission pilot shaft will appear.
smear it with red spline grease and put it back together without even removing the back wheel.
2Back to top Go down   spline job Empty Re: spline job Wed Sep 21, 2011 3:10 am
good tip mikeeee
3Back to top Go down   spline job Empty Re: spline job Thu Sep 29, 2011 12:04 pm
dinos735
dinos735
What a great tip. Thanks a lot. I didn't even think about that. I have used that trick on cars, but never even thought you could do it that way on a k-bike. Isn't there a seal in between the housing?
What do you say? Thanks Dino
4Back to top Go down   spline job Empty Re: spline job Sat Dec 17, 2011 12:45 am
Lazyboy
Lazyboy
GREAT idea Mikeeee I am going to try it this week.
1984 BMW K100RT
Bikes Name: Lazyboy
5Back to top Go down   spline job Empty Re: spline job Sat Dec 17, 2011 4:17 am
spline job 212902
I use this trick to slide the gearbox in place, but never thought of using it for the final drive.
Good one!
spline job Frog15spline job Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
6Back to top Go down   spline job Empty Re: spline job Sat Dec 17, 2011 7:05 pm
G'day Mikeeee,Thanks for that great tip.Although Ulrich had mentioned it to me,have never been quite game to try.I'm halfway through the spline lube job with swing arm removed so should attack the clutch splines as well using the 4 bolts????.Just waiting for the right grease to arrive from Collins Indust. Dist.i.e. Molybond GA50. Cheers Tom Grabau
7Back to top Go down   spline job Empty Re: spline job Sat Dec 17, 2011 9:46 pm
Tom Grabau wrote:G'day Mikeeee,Thanks for that great tip.Although Ulrich had mentioned it to me,have never been quite game to try.I'm halfway through the spline lube job with swing arm removed so should attack the clutch splines as well using the 4 bolts????.Just waiting for the right grease to arrive from Collins Indust. Dist.i.e. Molybond GA50. Cheers Tom Grabau
It's a good trick but I have never used it on a K because I have never pulled a gearbox to do a spline but done the spline when I have had the gearbox out for work on it or a clutch.
8Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 2:58 am
Dennis
Dennis
Tom, and others, you may find that if you use the GA50 by itself it will dry out on the splines, though it'll take some time for that to occur. I mix a very heavy base oil grease with it, approximately 3 parts GA50 to 1 part grease. The grease I refer to is Castrol Optimol Optipit, with a base oil of 1000 Cst viscosity (many greases are around 220 Cst), and this particular product has a tacky additive also. I mix it up in a small container using an icy-pole stick. If you wish you can also add some powdered Dixons graphite. You will then have a product similar to the Guard Dog stuff from the US as it is a combination of Moly and Graphite and it's reputed to be excellent for heavily loaded spline applications.
9Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 5:38 am
Would bearing grease do the job ? I have 2 litres of SKF LGMT 2TH/2 sitting in the shed doing nothing .
10Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 7:29 am
Dennis
Dennis
The SKF grease LGMT2 is an all purpose automotive grease of grade 2 spec. It has a base oil of 110 viscosity and no tacky additives. It is suitable for wheel bearings and such. It's not really what is required for our application. This application is fairly unique, not often seen in industry, rare in automotive circles these days, but quite common in agriculture on PTO applications but all those situations are short use types (impliments etc). So a special application requires a special solution, that's why we need to get it right. If you intend to mix the GA50, try to find a grease which is recommended for extreme loads and slow speeds, these will normally have tacky additives and some Moly (around 3-4%), but the heavy base oil is what is required. Belray make one called tool joint compound, it is recommended for diamond drilling rod connections. Hope this helps.
11Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 3:01 pm
Thanks Dennis. The reason I asked is that I had to get the grease for a particular job and have heaps left over. Have you ever had one of those days when the wheels fall off?
Well last week I did. Had the plough out for about 15 acres, checked my right all the time to see whether the wheel was following in the right spot and then glanced to my left. Something wrong....wheel missing..It fell off about 10 metres earlier. Even though I had checked the bearings at the begining of this exercise, the outside bearing of the wheel collapsed. Boy the wheels fell off that day!
12Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 3:09 pm
Sorry, forgot to ask..how much Molybond GA50 will I need for the job ?
13Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 4:48 pm
Probably around a teaspoon. Cover it, but don't slather it around.
14Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 5:25 pm
caferacer62
caferacer62
Well finally did the spline lube thing on saturday, pulled the driveshaft out and did inner as well. Only problem being when i pulled the F/D off there was about an tablespoon full of oil sitting at the end of the driveshaft. Also some oil underneath at the gearbox vent hole 🇳🇴
So i cleaned everything down, pulled the centrestand so i could degrease underneath. Put it all back together(even put the new springs on the side/centre stand) and checked on Sunday to see if there was any oil anywhere, there is a dribble coming out from the bottom of the gerabox.
So it looks like the gearbox input shaft seal is gone as well as the output shaft seal.
Going to see if i can get the seals from Bearing Services ( we get all our stuff of them here at work) Just got to work out what sizes they are.
Anybody no off hand what they are. The spline lube was dead easy though, thanks to all the info on here.
Bert 2.0
spline job 170874
15Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 7:43 pm
Is there product from Loctite that will do the job? I have problems getting the other stuff.
16Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 8:27 pm
I can't find anything from Loctite but the came mob market a Dow Corning moly grease that seems to be much the same as any others and about 3% moly.
17Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 10:30 pm
Thanks K Freak, I'll try and chase up some. Blackwoods here can get get Molybond but by the 2 litre....bit too much in quantity and cost. No one else can stock the stuff or get it.
18Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 10:35 pm
Ainsjac, I've PM'd you.
19Back to top Go down   spline job Empty Re: spline job Sun Dec 18, 2011 10:40 pm
Tom Grabau got some from this mob Tom, Collins industrial distributors on 1800 004 157 will be able to tell you.
20Back to top Go down   spline job Empty Re: spline job Mon Dec 19, 2011 5:48 am
BIG D
BIG D
Cool
Rocol do a 50/50 moly compound they of chain grease fame I have seen it used in the mob.
BIG D
21Back to top Go down   spline job Empty Re: spline job Fri Feb 03, 2012 12:36 pm
Fifth Horseman
caferacer62 wrote:Going to see if i can get the seals from Bearing Services ( we get all our stuff of them here at work) Just got to work out what sizes they are.
Most of the bearing / seal sizes are shown on RealOEM
Sizes in mm, id x od x depth
Gearbox input shaft seal 22X35X7
Gearbox output shaft seal 25X40X7
Clutch pushrod seal 9X15X4
22Back to top Go down   spline job Empty Re: spline job Tue Feb 14, 2012 11:59 am
neobiker99
neobiker99
Great tip might try it out next week if the weather warms up a bit much to cold down the garage otherwise,been below zero lately.
