1Back to top Go down   Throttle keeper or cruise control Empty Throttle keeper or cruise control Mon Feb 06, 2012 4:50 am
sensei
We are planning a 5500 km trip this summer from Denmark through Sweden, Finland and Norway all the way to North Cape (Nordkapp) and back and experience tells me that long driving could be a challenge to my right wrist. Is it possible to adjust the resistance in the throttle roll, so that I don’t have to hold all the spring force with my wrist? I have also heard of a fairly simple devise which can be fitted the throttle roll; a kind of a paddle, on which you can lean your hand and take off the load and twist of your wrist - but I can’t find it anywhere. Anybody out there who can assist and is it possible to fit it on a K100? Or do you know of a better and more suitable product, such as a cruise control system (which is fairly simple to fit)? Cheers from Finn
Throttle keeper or cruise control 1106080553
dee why
dee why
Hi Sensei,
Is your right control block tapped to accept the OEM throttle friction screw - best option I think. Look for a plastic blank on the underside of the block.
http://www.maxbmwmotorcycles.com/fiche/ShowImage.aspx?image=Diagrams/B0000677.png&rnd=10241452
Looks like number 26 locking screw.
Or http://www.mandp.co.uk/productInfo.aspx?catRef=503589
Or bar end cruise control - $$.
dee why
If you google Throttle Rocker or Crampbuster you will find the paddle thing you speak of.
I have just finished installing a real cruise control (just like a car) on my K1100 but you may want one that is a bit easier to install.
Try this place http://www.mccruise.com/home.php?cat=248
Agerbundsen
Agerbundsen
There should be a friction adjuster screw on the throttle - at least there is one on mine.
The paddle is available at Biltema in Næstved. I do not know if it fits the K100, but it seems to work OK on my brothers' Yamaha. There are two partnumbers, 82170 and 82427. Price of 40 or 45 DKK should not break the bank.
sensei
Thanks to all for your advise and thanks to Agerbundsen for notifying me that I can get the item round the corner in Næsted..... Smile
/Finn
6Back to top Go down   Throttle keeper or cruise control Empty Re: Throttle keeper or cruise control Mon May 07, 2012 10:09 am
GB777
GB777
I have the Audiovox CC-100 fitted as well as the bar end Cruise. I find the Audiovox (vacuum operated) is the best on dual carriageway roads up and down hills etc. where you are not wanting to slow down for cars or sharp twisties. The bar end cruise I use for the non boring roads eg. twisties constant slowing down and speeding up.
I looked at the factory friction screw... but thought it was a bit more difficult to set being under the switch block.
Gary
'94 K1100RS Mystic Red
•Dyno Tuned to deliver 115 bhp. •Audiovox CCS-100 Vacuum Cruise Control. •Fuel Plus Version 3.1 Trip Computer. •R1200c Final Drive Gears (32/13 or 2.54). •Ohlins rear shocky. •K100 complete Aluminium Radiator fitted. •Davies Craig Thermo Switch fitted to Cooling Fan with manual over-ride. •Fuel Cap drilled and tapped to provide mounting points for accessories, including mini Tank Bag & Apple CarPlay Screen •HID Hi-Lo Headlight and every other incandescent bulb on bike replaced with LED's. •Bulb monitoring warning light no longer needed so it's now used to indicate when Side Stand is down. •LED (Halo) Front Park Light (BMW Car style).
