1Back to top Go down   illuminated clocks Empty illuminated clocks Fri Feb 17, 2012 11:38 am
komandoalicante
komandoalicante
Well some of you already know my mania to make the watches are well lit
This is a simple and cheap
We did a system concept of this but with blue LEDs were not very good.
illuminated clocks Cimg3691t
illuminated clocks Cimg3696
The diodes and resistors have cost € 3.45 and also we must shrink sleeves in my case of 2 diameters
Note that the diodes have the longest polarity is negative
illuminated clocks Cimg3697y
illuminated clocks Cimg3700y
illuminated clocks Cimg3701z
illuminated clocks Cimg3702i
illuminated clocks Cimg3705o
illuminated clocks Cimg3706b
illuminated clocks Cimg3709f
The first case (left) isolates the terminal of the diode and resistance, then we put a cover and isolate the other diode terminal taking it back, then we put the other case we weld the diode resistance and isolate the remaining aa sight.
illuminated clocks Cimg3710y
illuminated clocks Cimg3711q
illuminated clocks Cimg3712
illuminated clocks Cimg3719h
illuminated clocks Cimg3720
illuminated clocks Cimg3722a
I have passed under the wire by passing it through the hole, so when goals faston connector cable firmly subject, so installation is very easy to undo.
illuminated clocks Cimg3723x
I have soldered the negative terminal of the diode to the chassis and so put him to ground and clamping circuit that does not move.
illuminated clocks Cimg3726
illuminated clocks Cimg3727d
SAK3 and komandoalicante is the same person
In March we made a International meeting  KEDADA ALICANTE of BMW motorcycle K in  Spain.
The last meeeting  March 2020
https://youtu.be/hfqxlGeEVsY
https://picasaweb.google.com/100417997445250027277
2Back to top Go down   illuminated clocks Empty Re: illuminated clocks Fri Feb 17, 2012 3:04 pm
Blue is the worst colour for readability at night, I think that green is the optimum sensitivity of the eye so the writing seems really clear.
