1Back to top Go down   Draining the fuel tank. Empty Draining the fuel tank. Thu Feb 02, 2012 6:23 am
Steve75
Steve75
Hi Guys
I put some fuel in my k100rs today and got it started after 6 years of it sitting under a cm of dustt (I also did an oil change). The bike started wonderfully, i was quite suprised. Problem now is that ive got about 5 litres of fuel dripping from a tiny hole somewhere underneath. I intend on removing the tank eventually but in the short term what is the best way to drain the remaining fuel??? Any help would be great.
Steve
2Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Thu Feb 02, 2012 8:30 am
Syphon it is the way I have to do it and as for the hole it is most likely just under the pump where all the crud is drawn to. The aluminium gets coroded and eventually a hole appears. I have fixed several now and use the permatex stuff that comes in a dual strip. You just nead it till its mixed and press it over the hole after a good sanding to bare metal, let it set for 36 hours and bobs your uncle (Aussie for done and dusted). I have never had one leak yet after that stuff.
3Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Thu Feb 02, 2012 8:54 am
Steve75
Steve75
Thanks K Freak
I ended up syphoning all the fuel out as it was stinking out the garage. Where is the best place for buying permatex and I am guessing that it goes on the outside of the hole. I'm located in NSW so we should have similar stores to QLD.
Steve
Steve
G,day from Oz Draining the fuel tank. 502531
4Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Thu Feb 02, 2012 9:00 am
Just about any auto store will have it. I got mine from an Auto One store. Its a ribbon of epoxy about 25mm wide and blue one side and grey the other.
I know about the fuel stink I pulled some injectors of an old K100 engine a few days ago and the rotten fuel is still stinking the place out.
5Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Thu Feb 02, 2012 9:16 am
Toto_jp
K100 RS 1986
6Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Thu Feb 02, 2012 10:01 pm
On my solo I repaired the leak by opening up the hole and using a nut and bolt with fibre washers and jointing compound; I did the outfit with a self-tapping screw and JB Weld. Both have been OK for more years than I care to remember.
Is this Permatex ethanol proof?
7Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Fri Feb 03, 2012 12:48 am
sidecar paul wrote:On my solo I repaired the leak by opening up the hole and using a nut and bolt with fibre washers and jointing compound; I did the outfit with a self-tapping screw and JB Weld. Both have been OK for more years than I care to remember.
I can't say for sure Paul but most likely. I only put ethanol in mine when I know I will be running it out in a few hours and never let it sit even overnight, it absorbs any water in the tank and gets rid of it. It is most likely that water caused the hole in the first place.
8Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Fri Feb 03, 2012 7:55 am
Steve75
Steve75
I removed the fuel tank today and found that someone else had made 2 dody looking repairs to some fairly big corrosion holes. I ended up cleaning everything away and starting again. Hopefully it will hold. If I can work out how to attach a photo to the forum I will show you.
9Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Fri Feb 03, 2012 8:11 am
10Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Fri Feb 03, 2012 9:46 am
Steve75
Steve75
Draining the fuel tank. Imag0112Draining the fuel tank. Imag0113
Steve
11Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Fri Feb 03, 2012 10:41 am
looking a little better steve ...
12Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Sat Feb 04, 2012 11:39 pm
Wow Steve, I've never seen one that bad before. If that's permatex you've used, keep us posted as to how it holds up over the next few months.... or years.
I've just had a swig of your virtual beer....cool.
Paul
13Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Sun Feb 05, 2012 12:27 am
Just looking at those photos Steve it appears the material has shrunk a little towards the centre of the patch. If it's done the same on the inside I would be inclined the give it another thin layer for strength.
88KE
Last edited by 88KE on Sun Feb 05, 2012 11:53 pm; edited 1 time in total (Reason for editing : Correcting the auto corrector!)
14Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Sun Feb 05, 2012 2:46 am
I agree with 88KE height is not an issue there so a good layer is no problem.
15Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Sun Feb 05, 2012 8:44 am
Steve75
Steve75
I can see what you are looking at and I thought the same thing. I was able to get my finger on the hole from the inside and spread a little of it there as well, so it is sealed for now, only time will tell. If it leaks again I'll get the tank welded. It looks like aluminium ,am I correct???
Steve
16Back to top Go down   Draining the fuel tank. Empty Re: Draining the fuel tank. Sun Feb 05, 2012 1:44 pm
Steve75 wrote:It looks like aluminium ,am I correct???
Spot on.
