1 Hassle Free Method of Dismantling and Reassembling Bike Sun Feb 05, 2012 5:18 pm
FreebasserSF
Hey guys,
I know this is probably a more general automotive maintenance comment, rather than a k100 specific one but I thought I would let you guys know a system I have been using to avoid the Bermuda triangle effect, where the tiniest pieces seem to want to fall off the work bench and never be seen again or get kicked while they are on the floor and disappear. I bought a whiteboard and dry erase markers and make little boxes with the parts' names or descriptions and then they stay nicely labeled and stationary in one spot. As you remove a piece to label it then as you put the bike back together you erase the label. Works like a charm! I know it seems like its not that much different from setting them out on a counter top or something but it makes for a very brainless and hassle free process and might I add extremely fast! Where the big parts you remove go is usually pretty obvious, but it is all the washers, bolts, clips, connecters, and bushings that really mess you up. I've been trying to post an article with a tip of some sort for each one I post requesting help so I don't feel like I'm mooching.
