1Back to top Go down   K100RT No Voltage - Good Battery Empty K100RT No Voltage - Good Battery Thu Dec 01, 2011 4:16 pm
BadjerJim
BadjerJim
HELP -
Okay, I hadn't ridden my 1985 K100RT in about a month. This Saturday is the charity Toy Run for our town. So I went out and hooked up my battery charger to make sure the bike was ready.
Wow: turned the key, and the dash lights were bright. So I punched the starter button. Got a grunt from the starter, but no start. Waited a minute. Punched the starter button again, got a 'grunt' from the starter... and then nothing. Lights out on the dash (no neutral light, warning lights, nothing.)
Pulled and checked all the fuses under the left side cover... they're all fine.
What did I screw up? What is blown? Is there a secret fuse somewhere? I can understand if the starter won't crank due to low voltage, but this is something else.
PLEASE HELP - the Toy Run for charity is in 2 days. Where should I start? Anybody have a problem similar to this? THANK YOU! direct email = badjerjim@gmail.com
2Back to top Go down   K100RT No Voltage - Good Battery Empty Re: K100RT No Voltage - Good Battery Thu Dec 01, 2011 4:30 pm
I would take the battery out and have it checked at a battery place. Quite often a battery will show fulled charged and will power small lights but doesn't have enough charge under load. The battery people will check the voltage and then place it under load...different story, it may only have a few volts under load. That way if you need a replacement battery, you are in the right place to save time. Hint, ask them to get a replacement for your battery.....not for a BMW. Once BMW is mentioned the price goes up. Good luck.
3Back to top Go down   K100RT No Voltage - Good Battery Empty Re: K100RT No Voltage - Good Battery Thu Dec 01, 2011 4:43 pm
This is certainly a problem with your starter. First thing to try: put the bike in second or third gear then push the bike for a foot or 2 (back and forth). This will move your starter rotor to another position. Do this with the ignition ON and see if you get the lights working again.
If the lights are working again, the best thing to do is to remove the starter (only 2 screws) and clean it.
If the brushes are bad, the starter won't work and the load shed relay won't be activated.
Check the circuit of the load shed relay Here. Click on the top tab "starter"
Rob has posted a very good tutorial on cleaning the starter (Check this)
K100RT No Voltage - Good Battery Frog15K100RT No Voltage - Good Battery Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
4Back to top Go down   K100RT No Voltage - Good Battery Empty Re: K100RT No Voltage - Good Battery Thu Dec 01, 2011 4:52 pm
BadjerJim
BadjerJim
Crazy Frog - THANK YOU
Your diagnosis makes sense. I will try that and let you know.
Again: big thanks to this forum and all who participate.
5Back to top Go down   K100RT No Voltage - Good Battery Empty Re: K100RT No Voltage - Good Battery Thu Dec 01, 2011 4:57 pm
Just don't claim victory too fast even if I am confident that your problem is the starter.
You may not even have to open it right now. If pushing the bike back and forth once works, it will work again.
This is a good winter project!
Good luck buddy (Hey he's not an Aussie and I cannot call him 'Mate')
6Back to top Go down   K100RT No Voltage - Good Battery Empty Re: K100RT No Voltage - Good Battery Thu Dec 01, 2011 6:33 pm
Crazy Frog wrote:Good luck buddy (Hey he's not an Aussie and I cannot call him 'Mate')
touche bert Very Happy
good luck jim
7Back to top Go down   K100RT No Voltage - Good Battery Empty Re: K100RT No Voltage - Good Battery Thu Dec 01, 2011 8:19 pm
A mate is a mate, doesn't matter what country he's from.
8Back to top Go down   K100RT No Voltage - Good Battery Empty Re: K100RT No Voltage - Good Battery Thu Dec 01, 2011 8:20 pm
Yes you'r right buddy!
9Back to top Go down   K100RT No Voltage - Good Battery Empty Re: K100RT No Voltage - Good Battery Thu Dec 01, 2011 8:35 pm
Crazy Frog you may be a buddy, but you are also a mate....dual citizenship!
