1 Replacing the left handlebar switch Tue Nov 15, 2011 11:23 am
claudejones
The Haynes manual I have says nothing about the handlebar switches to speak of. From internet searches, it looks like the cable connects to the wiring harness up under the tank somewhere. Is this correct? If so, do I need to fully remove the tank to get at the connection - I've heard that you can remove the fasteners and lift the tank in place quite a bit? If I do need to remove it, do I need to worry about gas going everywhere when I disconnect the gas line? Any other advice or suggestions on replacing the switch would be appreciated.
