12 rivet output shaft .. When? Mon Jun 03, 2013 11:30 am
![avatar](https://i.servimg.com/u/f41/11/71/56/74/avatar10.jpg)
Now that parts for round one repairs are arriving and being installed I've been looking at round two, which is a rattle only when cold. I put this down to the cam chain tensioner, it sounds like chains, but searches seem to show a possible rivet issue and when 12 rivet output shafts first appeared is a bit ambiguous. I thought 86.
Without looking inside, can I otherwise tell if this 05/86 R100RS has 6 or 12 rivets on the output shaft?
I've also read if the rivets have an issue and the gearbox is out, as it is, you can feel slop in the output shaft. Tried that and can't feel any so I'm hoping I can rule that one out.
