1 Back to "bike will not start" Thu Jan 22, 2009 3:27 am
roys
Hi all,
After forced 2 weeks rest, and as ribs are mending, I am back to dealing with the problem of bike refusing to start.
Yesterday I finished putting in the H4 kit from “easterbeaver” and now I have a powerful source of light, stationary... but powerful...
With your permission I want to sum up status with bike and perhaps someone will have some insight how to continue, to ease the discussion I numbered each statement.
1. Bike is a 1987, naked or “base” K100 with about 140K KM.
2. Till this event bike ran very well – only issue was eating a little oil and not so good fuel efficiency – but really ran very well so decided not to play with this and deal with other issues before.
3. Bike has never before failed starting up, I did flood it once, a month before, but after 30 minutes (in summer sun) all was well.
4. Oils and filters less then 1000KM/ 2 months old.
5. Day before failure I had a great 3 hours ride and bike was behaving very well.
6. At end of ride I filled tank completely at a station that is not my usual one (and is only 1.0Km from home).
7. Next day early morning bike would not start.
8. Also would not start downhill – no misfiring – simply nothing.
9. I think a very important indication is the suddenness of the failure, there was no gradual process leading to this.
a. Question: Are there any internal switches that can “kill” / prevent proper start?
10. There is no micro-switch in side stand (regardless I ALWAYS use central stand).
11. IIgnition witch is OK as far as bike electrics are turned on with no issue (lights and indicator lights are strong).
12. When pressing the start button:
a. The starter makes its usual sound (had a friend who is mechanic listen as well.)
b. Question: How can I know if it is turning the engine?
c. Fuel pump can be heard working.
d. After disconnecting fuel line and then pressing the start button, fuel squirts from tube so I ASSUME pump is doing its job?
13. Battery showed 12.4V, connecting my cars battery to bikes battery made no difference.
14. All fuses are intact and correct.
15. Sparks are OK (asked a friend who is experience to have a look as well).
16. Sparkplugs (Bosch x5dc) had some black coating, rather soft.
a. As per HAYNES manual they look something between pictures called “carbon fouling” and “oil fouling”. But spark was good.
b. Regardless, I replaced with new NGK (D7EA) – they too have clear spark.
17. I disconnected, cleaned and reconnected the “ignition control unit” and the “computer” (connections look very good - no free movement)
18. With fuel tank off I pressed start and try very closely to see if any sparks or foul smell come from electric wiring – nothing.
19. I drained fuel completely by siphoning of the tank and then disconnected fuel line and with a few very short presses on start button had it spew out remaining fuel.
20. I replaced fuel with new fuel bought at regular gasoline station and also used to refill car on SAME occasion. Car ran fine (till I wrecked it). I also added some magic potion that is supposed to take water out. I tried again next morning and no difference.
21. There is very little gas smell during all these attempts.
22. Throughout all the attempts there is no misfiring ever, sound is “dry”.
23. Question: How Do I test if fuel is coming out of the injectors – I am hesitant to touch this system – is it possible to take them out one by one and see them spray?
24. Questin: Is it possible that ignition switch will operate lights, starter, sparkplugs and fuel pump but NOT send fuel thru injectors?
25. And finally - what next?
Sorry this is a bit lengthy but perhaps better then a very long back and forth.
I have the HAYNESS and CLYMER manuals but it’s like reading a medicine book – you immediately think you have 90 different diseases.
I really welcome all ideas, it’s all new to me.
Thank you,
Roy
Thank you,
Roy
