1 Converted to round headlight, now only works on pass. Worked before! Fri Nov 04, 2011 5:38 pm
scabzzzz
Hello all,
The bike: 1985 BMW K100RS
Ok, here is the drill. I bought the bike, rode it home ~80 miles or so. Everything great, everything works. The goal with this bike is to make it a basic non touring type bike, a la naked Ducati Monster style or cafe-ish. First step, ROUND HEADLIGHT.
I had a Hm headlight with bucket (H4 type bulb, 60w) and some universal brackets. Mounted the light. Everything good. Noticed some melting in the wires going to the headlight connector. I immediately pulled the shielding plastic back and started to trace the melted wires. Turns out, all 3 wires (brown/white/yellow) had melted together. The melting had stopped about mid tank in the harness. Snipped off old shit wires, crimped on new ones. I have high beam going to the wire labeled PASS on the light harness, low beam wire going to the LOW, and the ground wire into GROUND. Confirmed all fuses were good, and even replaced them anyways. Tail light works, blinkers work. Pass works, but no low or high beam. I check for 12v at the headlight harness where it connects to the light, I get a little under 12v for low, but nothing for high. Ive tried reversing the low and high wiring where it plugs into the headlight harness, no change. Pass always works though. What gives? Any advice?
Btw, I found other random melted wires once the tank was off. Some worse than others but not nearly as bad as what i found on the headlight harness. Is this common? What could have done this?
Thanks guys!
Thanks guys!
