1 Fuel Pick Up problem Sun Oct 02, 2011 9:32 am
Sidecarjohn
I realise the problem of fuel pick on the K is fairly well known, but is there a realistic solution ?
When the tank still has over a gallon (5 litres) remaining, misfires occur usually when cornering fairly hard. OK we run an outfit, which will mean there's the effect of the bike not leaning, but the problem is a known issue regardless.
Any suggestions as to a viable solution, so that I can actually benefit from having a 20 litre fuel tank ?
