1Back to top Go down   Fuel pump vibration damper Empty Fuel pump vibration damper Fri Sep 23, 2011 3:41 pm
purkolator
So, upon inspecting the inside of my fuel tank yesterday while removing it for some other service, I found that the fuel pump surround has started to go. If I wipe the edge of it with my finger, I get black gunk on me. It's not completely disintegrating, but I'm sure that it's slowly clogging up my brand new fuel filter and could well be adding to my rough running/surging woes detailed elsewhere on this forum. Anyhow, a few questions...
Wow, that piece of rubber is expensive! $80+ from BMW! for rubber! Hmmmm... particularly annoying since I live in a state where most gas stations mix in ethanol and I know that a new one will start to disintegrate in short order with that stuff preset. So... my question...
-Any aftermarket options?
-Anyone ever try to fashion some kind of replacement out of fuel hose/foam/playdough(kidding on the pd)?
-If so, any idea what materials won't start to break down in Ethanol gas?
thanks!
Brad
2Back to top Go down   Fuel pump vibration damper Empty Re: Fuel pump vibration damper Fri Sep 23, 2011 5:44 pm
purkolator
So, I'll answer at least one of my own questions. Found this Enudralast part that is supposedly alcohol resistant. Still pricey though...http://www.euromotoelectrics.com/BMW_K_Rubber_Vibration_Damper_16_12_1_464_628_p/fp-576damper.htm
