1Back to top Go down   Heated grip fuse - wire missing Empty Heated grip fuse - wire missing Wed Sep 21, 2011 2:47 am
ricketyclik
ricketyclik
Hello group,
I rewired my heated grips into the socket under the tank, turned on the ignition - nothing.
Checked the fuse - not there. Moved one of the others and noticed that the left receptor as you face the fuse box from the side of the bike is not there. Pulled out the fuse box, and there's no wire leading from where the receptor should be.
Any advice? Please keep it simple, as I'm not an electrician and don't know much about it.
ricketyclik 1987 K100RT Canberra, Australia
2Back to top Go down   Heated grip fuse - wire missing Empty Re: Heated grip fuse - wire missing Wed Sep 21, 2011 4:34 am
rickety ....maybe a look round an automotive shop could help ....what im thinking is, maybe you could find a similar mount up on another piece of equipment ??? (given that most of us wont have a spare )
or does someone ?
maybe twb has a line on a part number..... wortha try anyhow mate
3Back to top Go down   Heated grip fuse - wire missing Empty Re: Heated grip fuse - wire missing Wed Sep 21, 2011 5:31 am
The genuine heated grips is feed from fuse #1, together with instruments, tail and brake light.
Normally fuse #4 is missing (and the receptor), that fuse is for power socket (when mounted).
4Back to top Go down   Heated grip fuse - wire missing Empty Re: Heated grip fuse - wire missing Wed Sep 21, 2011 5:39 am
hmm good info inge ...might help solve albys ...mysterious fuse blow up last weekend whilst on a ride....thanks mate
5Back to top Go down   Heated grip fuse - wire missing Empty Re: Heated grip fuse - wire missing Wed Sep 21, 2011 5:56 am
If it was #1 that did blow, it`s possible that it is a short in the circuit for the heated grips.
Connector for heated grips is on left side under the tank, one green/black wire and one brown.
6Back to top Go down   Heated grip fuse - wire missing Empty Re: Heated grip fuse - wire missing Wed Sep 21, 2011 6:34 pm
ricketyclik
ricketyclik
Actually, I was just trying to disconnect my aftermarket connector that I replaced the OEM one with, then retried one more time and it worked. Must have been my sloppy connector assembly.
Thanks for the input guys.
