So, of course I decided to delve deeper. Was still feeling something not right. One day on the ride to work it felt kind of like it was running on only 3 cylinders... Power not quite what I expected unless I really wrung out the throttle and a slighty rough feel and sound from the engine. The night before I had tweaked the position of the TPS for less slop. I surmised that I had probably bumped the ignition wires connections at the coil and began to suspect bad wires. I had tested the resistance of the wires before and they seemed to look ok but intermittent cables can be deceptive. Ordered up a replacement set from euro-moto electrics. Yet to arrive.
Also was suspect that the throttle bodies needed resynced after all the interim activities so got a SyncPro this weekend and hooked her up. After calibrating it, I hooked up all 4 lines to the bike to find #1 significantly lower than 2,3 and 4. Check out a quick youtube video of a test below. Couldn't get things even close with the brass screws so I left things be for a bit.
After a bit of a think decided to check my valve clearances. I already know compression is good but hadn't checked the valves since purchasing. This was a first time project for me, so it was quite fun to get in there and get a bit of oil on my hands. After sacrificing a roll of paper towels and a spot free driveway, I came away to find my clearances seem to be looking pretty good. So I button her back up.
Then decided to poke around on those ignition wires a bit and see if I could find a weak spot. In the process of doing this I pull the wires off the bottom of the coils and peer up into them... hmmm, #1 looks different... Pull off the coils and find that the high voltage terminals on 2,3 and 4 are bright and shiny and #1 looks super dull and kind of dark ( see pic below). Ok, so I treat the terminal with DeOxit twice and and am able to clean off something but the terminal still looks very different. When I go to measure the resistance I am perplexed. I get the expected couple of ohms on the spade terminals but between the two hi voltage terminals... It reads as an open. In fact both coils are like this. I know that some K75 had gaps in the coils but did K100s?
Put the coils back on the bike she starts right up but still has the same vacuum issue on 1.
So, not quite sure where to go next...
-Look for vacuum leak? Intake boots are new but it could be the air box to throttle body rubber. Tried to do the carb cleaner test a while back and couldn't tell a difference on any of them. Maybe I'll try that again and focus on 1.
-ignition? New wires should be here soon. How would/could ignition issues affect vacuum? New wires are on the way, not sure what to think about the testing I did on the coils.
-is there some Bavarian war dance I need to perform before I ride every day?
Thanks all
Brad
Throttle sync video
