1Back to top Go down   Output shaft install Empty Output shaft install Sun Sep 18, 2011 3:25 pm
hot_seat
hot_seat
Because the output shaft has a thin gear(anti backlash) next to the main drive gear,how do i mesh the gears to the crank gear,i don't wish to damage the gear,some how i have to squeese them together
Thanks for the advise
Tony:?:
2Back to top Go down   Output shaft install Empty Re: Output shaft install Sun Sep 18, 2011 4:52 pm
Pretension the gears using a long screw driver to mesh the teeth of both gears and clamp them in position with a small C-clamp or a wise grip.
After that, the output shaft will fall into place.
CF
Output shaft install Frog15Output shaft install Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
