1Back to top Go down   Is there something missing here?? Empty Is there something missing here?? Fri Sep 23, 2011 7:38 am
Agerbundsen
Agerbundsen
The silencer inlet has a "lump", which extends under the frame to the RH side. There are lugs with bolt holes both on the "lump" and on the frame - but they are about 15 mm apart, but otherwise line up - sorta.
Should there be a connection between the two? and if so, with a rubber bumper between?
I surmize that the "lump" is an expansion chamber to suppress some pressure peaks in the exhaust??
Part #14 in this picture.
Agerbundsen
Agerbundsen
It looks like it could be, but not quite.
http://www.flickr.com/photos/agerbundsen/6174398421/ has two pictures.
Some day I will figure out how to include the pic's in the post
4Back to top Go down   Is there something missing here?? Empty Re: Is there something missing here?? Fri Sep 23, 2011 10:23 am
i think inge is right agerbundsen ......you are looking for a rubber mounted spacer ....which looks to be a double ended bolt /
sometimes the layout of the parts catalogue is confusing
5Back to top Go down   Is there something missing here?? Empty Re: Is there something missing here?? Fri Sep 23, 2011 10:26 am
That`s the correct part, on your photos part #13 is still on the bike.
Posting pictures.
6Back to top Go down   Is there something missing here?? Empty Re: Is there something missing here?? Fri Sep 23, 2011 10:28 am
Thanks, Charlie.
7Back to top Go down   Is there something missing here?? Empty Re: Is there something missing here?? Fri Sep 23, 2011 10:36 am
Agerbundsen
Agerbundsen
You guys are just the best. Thanks
I found a rubber isolator at Biltema, which will fit till I can get the real thing. It will not be instaled till tomorrow, when I will try topost a pic.
Last edited by Agerbundsen on Fri Sep 23, 2011 12:34 pm; edited 1 time in total (Reason for editing : Additional info:)
