1Back to top Go down   What am I missing? Empty What am I missing? Thu Feb 23, 2017 9:38 am
genewilliamsgene
genewilliamsgene
In a tale as old as time I was working on something else when I noticed a few unplugged connectors in the box under my tank...
What am I missing? Img_2012
What am I missing? Img_2011
I have a climers manual and have looked through it but I am at a loss. I have no idea what these connectors should plug into.
So what am I missing gentlemen? where should these things plug into?
Thanks,
Gene
2Back to top Go down   What am I missing? Empty Re: What am I missing? Thu Feb 23, 2017 9:57 am
Those are connectors for dealer installed options like alarms, radios, sirens, and lights.
3Back to top Go down   What am I missing? Empty Re: What am I missing? Thu Feb 23, 2017 9:59 am
genewilliamsgene
genewilliamsgene
Oh! OK nice, I was getting worried! Thank you so much!
4Back to top Go down   What am I missing? Empty Re: What am I missing? Thu Feb 23, 2017 10:06 am
looks like nothing is missing ... don't fret about it
one of the multi pin connectors is for additional accessories almost always unterminated in just about all k bikes
5Back to top Go down   What am I missing? Empty Re: What am I missing? Thu Feb 23, 2017 10:15 am
Chocolate
Chocolate
Hey!
The white cable is used for BMW K75 - 1100
For a secure connection of extras like navigation, charge mobiles, extra light etc.
In the relaybox it was designed for alarm, 4 connections with earth, permanent + over ignition.
 8 A (96W at 12V) fuse 5 and 7 (15 A)
A german man is selling a cable for this connection
What am I missing? Img_2714
6Back to top Go down   What am I missing? Empty Re: What am I missing? Thu Feb 23, 2017 10:54 am
BobT
BobT
 8 A (96W at 12V)
That is what you call power, the alternator on my DUcati 250 produces 40w at max chat!
7Back to top Go down   What am I missing? Empty Re: What am I missing? Thu Feb 23, 2017 11:22 am
That won't run much of a starter......
Or does the Ducati have an older Kalorie type starter?
8Back to top Go down   What am I missing? Empty Re: What am I missing? Thu Feb 23, 2017 12:08 pm
BobT
BobT
92KK 84WW Olaf wrote:That won't run much of a starter......
You will be suggesting that it has indicators next!
9Back to top Go down   What am I missing? Empty Re: What am I missing? Thu Feb 23, 2017 1:16 pm
BobT wrote:
 8 A (96W at 12V)
92KK 84WW OlafThat won't run much of a starter......
Hmmm?????
How often does a alternator run a starter? Unless there is something seriously wrong, I think the starter is the precursor to the alternator. If the alternator is running, the starter has finished doing its job already. I suppose if you are jump starting another bike you could argue otherwise!Very Happy
What am I missing? Uk-log10 What am I missing? Sco-lo15
                              Paul  What am I missing? 905546712
10Back to top Go down   What am I missing? Empty Re: What am I missing? Thu Feb 23, 2017 2:43 pm
Paul
That was a Kryptic comment.
The Ducati only has a kick start. Using an electric starter [if it had one] with a 40W alternator would mean quite a few hours running to get the battery back to full charge....
Be good if you can make it down to France in September too.....kind of looking like I might get to go about 1/2nd September get to St Leon late 3rd September and stay there a bit longer, until 20th September. Ferry arrives Roscoff 7.30am so would have all day to maybe do the full 700km as I know the road well.
11Back to top Go down   What am I missing? Empty Re: What am I missing? Thu Feb 23, 2017 3:16 pm
BobT wrote:
 8 A (96W at 12V)
yep they were absolutely abysmal ...and 6 volts at that ...mind you, you needed to get the fly wheel - rotor remagnetised after about 10 years if you wanted that good output bob .
a special low current ignition coil was used from memory as well ...mine blew up so resorted to a vw replacement  I could chose to ride at night ....only if I charged the battery before hand or less than 30 kilometers before she was dead .   those  scr for rectifiers were a good laugh ...
12Back to top Go down   What am I missing? Empty Re: What am I missing? Thu Feb 23, 2017 6:34 pm
BobT
BobT
Mine has been converted to 12 volt and I have just fitted LED taillight and side light bulbs along with a mosfet regulator. I ride with side lights on as it is a legal requirement to have lights on here in France. I probably use no more than 5 watts with the brake on. The only other item that can consume any power is the headlight bulb and that is 35 watts. I have no intention of riding it at night as no one on my route would get any sleep due to the noise!
I should be out and about on it for the September meeting down here, it will feel safe when it is surrounded by visiting Ks.
