1 Fuel Heat Exchanger Sun Oct 30, 2011 7:38 am
bushyintas
Hi all.
This might be of some interest to those of us in the wasmer parts of hte world,
A fuel heat exchanger that cools the returning fuel, from the fuel rail just before it is returned to the tank.
Only one test ride so far but a marked reduction in the temp of the fuel in the tank that can be felt at your knees.
On using a laser thermometer on the start of the fuel return line, at the end of the fuel rail, measured approx 60 deg C and at the point where the fuel line returns to the tank only 24 deg C.
I will conduct further tests both with the inlet to the exchanger covered, take a reading of the temp of the fuel in the tank, uncover then immediately re ride the same route with the inlet open and retest.
I will post findings here when completed.
Regards Bushy.
See photos below.
left top, heat Exchanger with "Heat Shield " tubing..... right top, inlet hole cut in radiator cowl.
left bottom, installed exchanger..... right bottom, hole from inside with mounting clips.
Completed project over winter 2011 here in Tassie.
Regards Bushy.
See photos below.
