1Back to top Go down   K1100 vs K100 fuel tanks  Empty K1100 vs K100 fuel tanks Sun Nov 29, 2020 4:55 pm
Cafed
Cafed
I have a 1993 K1100 with a very slight fuel leak on the lower left side (I see here that this is very common). The tank on it uses the 130mm front mounting. I see the K100 uses the 90mm front mounting. Has anyone cut down the mounting pins on the K1100 frame and used a k100 second generation tank? There seems to be more of them available. Also I realize I have the smaller fuel pump in my K1100 tank. Does the larger K100 fuel pump run the same pressure? Thanks in advance for any help
2Back to top Go down   K1100 vs K100 fuel tanks  Empty Fuel pressure Sun Nov 29, 2020 6:39 pm
daveyson
daveyson
Hi welcome
I think the fuel pressure is determined by the fuel pressure regulator, don't know if the regulator is the same in a k1100.
 ~120,000 km
3Back to top Go down   K1100 vs K100 fuel tanks  Empty Re: K1100 vs K100 fuel tanks Sun Nov 29, 2020 7:00 pm
Clean it off down to bare metal where it's leaking then take it to a competent welder and let him have a look.
4Back to top Go down   K1100 vs K100 fuel tanks  Empty Re: K1100 vs K100 fuel tanks Sun Nov 29, 2020 9:07 pm
The tank with the wide mounting is for the K1100 with the two top frame tubes ( LT after early 93 and all the RS models) and the two are not interchangeable as the pressing of the bottom of the tank is different.
5Back to top Go down   K1100 vs K100 fuel tanks  Empty Re: K1100 vs K100 fuel tanks Sun Nov 29, 2020 9:18 pm
Cafed
Cafed
RicK G wrote:The tank with the wide mounting is for the K1100 with the two top frame tubes ( LT after early 93 and all the RS models) and the two are not interchangeable as the pressing of the bottom of the tank is different.
Thank you yes the backbone of my frame splits off in 2 pipes from the steer tube. I have never had a K100 so I did not realize they were different. I guess I need to fix what I have or find a K1100 tank
6Back to top Go down   K1100 vs K100 fuel tanks  Empty Re: K1100 vs K100 fuel tanks Sun Nov 29, 2020 9:19 pm
Cafed
Cafed
MartinW wrote:Clean it off down to bare metal where it's leaking then take it to a competent welder and let him have a look.
Looks like I may have to take that route. Thanks
