1 Front Master Cylinder rebuild Mon Jul 18, 2011 1:03 pm
nick
I replaced the piston but still has a leak. I appears to be leaking between the plastic fluid container and the metal base. Are those pieces connected by a seal?
Quite familiar with that one....have been in the need of drilling the head of those screws on several bikes.charlie99 wrote:thanks inge .....mine has started to leak also ....since i finally was able to undo the last screw "locktited " in and stripped phillips head socket .
Similar topics
