1 Splines at gearbox end of drive shaft. Sat Jun 11, 2011 9:17 pm
Avenger GT
The splines on my drive shaft and final drive unit are badly worn, so I will have to replace both shortly. The current shaft is a 16 spline unit. Does anybody know if the splines at the gearbox end are the same on the 16 spline and the 20 spline drive shafts, or are they different? Since I need to replace both the shaft and final drive it would give me more choice of used replacements if the gearbox ends were the same.
