1Back to top Go down   Headlight does not work properly Empty Headlight does not work properly Tue May 24, 2011 12:50 pm
Now I've finally got my bike back on the road I noticed that the high beam does not work! If I switch from low to high beam the light goes out but if I press the passing light switch, high beam comes on. My bike is a USA spec so I cannot turn the lights on and off like on the UK version.
Could the instrument panel issue have anything to do with this?
Thanks for any help.
2Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Tue May 24, 2011 5:14 pm
What is the 'passing light switch'?
Are you talking about the flasher?
Headlight does not work properly Frog15Headlight does not work properly Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
3Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Tue May 24, 2011 5:39 pm
Crazy Frog wrote:What is the 'passing light switch'?
The the switch is the same as the headlight but it just flashes the headlight on high beam.
4Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Tue May 24, 2011 7:21 pm
kg4miq
I suspect the switch itself is the problem. Can you disassemble it?
1985 K100RT
S/N 0051848
5Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Tue May 24, 2011 7:24 pm
kg4miq wrote:I suspect the switch itself is the problem. Can you disassemble it?
I can have a look at it later on this week. It may just be some dirt then?
6Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Tue May 24, 2011 9:16 pm
In the download section (under the electrical section) you will find a tutorial on how to dismantle the switch.
CF
7Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Tue May 24, 2011 10:37 pm
club_c
club_c
Yup, same problem, dirty contacts inside the switch. Before you pull it apart, buy some DeOxit spray to have on hand.
8Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Wed May 25, 2011 11:55 am
How do I get to the download section when using 'Chrome'? The browser sends me to 'Member's introduction'!
9Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Wed May 25, 2011 12:01 pm
10Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Wed May 25, 2011 12:21 pm
Crazy Frog wrote:Click here
Great, now the password which was sent out on 18/03/2011 does not open the link. Is there a new password?
11Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Mon May 30, 2011 2:17 pm
I looked at the switch this weekend and it seems OK. Is there a relay for the headlamp?
12Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Mon May 30, 2011 6:41 pm
There isn`t any relay in this circuit from factory, but it`s not unusally fitted afterwards, as burnt contacts in this switch is rather common.
As your low beam functions you have power to the switch, and that your passing light is in function confirms that this circuit is not open......the problem must be in the switch itself.
Unless there is made some weird modifications on your wiring.
13Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Mon May 30, 2011 7:35 pm
Inge K. wrote:There isn`t any relay in this circuit from factory, but it`s not unusally fitted afterwards, as burnt contacts in this switch is rather common.
I'll have another look at the switch. I possibly missed something very obvious!
14Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Mon May 30, 2011 8:02 pm
Pay especially attention to the contactpoints at the end of the white wire, it`s two points, one for pass the other for high beam.
I would strongly advice to mount relays, and avoid problems with this switch.
15Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Tue May 31, 2011 7:33 am
The kit from Eastern Beaver is excellently engineered and fits perfectly.
16Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Wed Jun 01, 2011 6:02 pm
Adiwan Djohanli
Adiwan Djohanli
I had the opposite problem before. My low beam was on and off during riding.
Later I found out it was the switch problem. I replace the whole switch with a second hand unit and it works well now.
Cheers.
Adiwan Djohanli
Jakarta-Indonesia[i]
17Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Thu Jun 02, 2011 6:11 pm
This is going to sound a bit crazy but, could a sticky starter relay have anything to do with the high beam not working properly? It's been really cold recently and the relay has started to stick 'on'. if I tap it lightly it disengages immediately.
18Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Thu Jun 02, 2011 6:43 pm
No, this is not related. As your low beam functions, the problem is in the switch.
High and low beam is feeded from the same wire to the dimmer switch.
About sticky starter relay: this is caused of a to weak battery, recharge or replace,
or you soon need another starter relay also.
Open the starter relay and clean the contacts, after the weak battery been sorted out.
19Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Thu Jun 02, 2011 6:46 pm
The battery was replaced about nine months ago and I ride about 75 miles per day so I think that it must be OK. I didn't know that the relay contacts could be cleaned. That was a useful tip.
20Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Thu Jun 02, 2011 7:06 pm
This thread could be useful: starter relay pictures
21Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Thu Jun 02, 2011 7:16 pm
The amount of DIY information on this forum never ceases to amaze me! Thanks again.
22Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Thu Jun 02, 2011 7:22 pm
The search button is your friend.
23Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Thu Jun 02, 2011 7:23 pm
lhead71
I just pulled my starter relay apart and brushed up the contacts, it is worth a look and it is pretty quick. I was able to get to the relay without removing anything other than the cover to the relay box.
24Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Thu Jun 02, 2011 7:32 pm
Inge K. wrote:The search button is your friend.
A friend it may be, but I don't always know what I should be looking for! Electrics are still a bit of a 'dark art' to me.
25Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Fri Jun 03, 2011 5:30 am
This thread about a light switch might be helpful for your other problem,
and adding some more to your know how about "dark art".
It is a photo of a burnt switch contact almost in the bottom of the thread.
Above the photo it`s a link to more photos of the same subject.
The link doesn`t function, use cut`n`paste into your browsers adress field.
26Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Mon Jun 06, 2011 2:23 pm
This weekend I spent a few hours giving Carpathia, my bike, the due care and attention she deserves. I checked the battery, cleaned the ternimals the protected them by smearing them with vaseline. After that the headlight switch got the going over and now I have both high and low beam again! Then an oil change and finally, the starter relay got a looking at, the points were quite dirty and I really think the relay should be replaced.
After doing just those few jobs, my enjoyment and pride in my bike has also been restored. Well she does around 700Kms per week so a little love doesn't do any harm!
27Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Mon Jun 06, 2011 3:04 pm
yay .....good work martin ....love that name carpathia ...giggles
28Back to top Go down   Headlight does not work properly Empty Re: Headlight does not work properly Mon Jun 06, 2011 5:38 pm
charlie99 wrote:yay .....good work martin ....love that name carpathia ...giggles
I like to give my vehicles names! My 1976 Benz is Lady Genevieve and the other Lady Augusta!
