Number of posts : 11701
nino ...we have seen many times that the starter relay becomes corroded on one of the contacts due to arcing ...many have replaced this relay .......
i think it would be important to also mention that the brushes on the starter motor also are a sorce of failure , in addition to causing some eratic electrical problems .
i have myself recently purchased a replacement set of brushes for exactly that reason , and now keep them in a plastic bag under the seat .
i have seen recently in this forum that at least one member has had an issue with the large power wire from the battery to the starter relay ....aparently the wire connections had become faulty for some reason.
in any case it would be a good idea to test these cables and see if there is some way of bypassing the relay ...maybe a wire bridge accross the starter relay from the battery and see if the starter turns correctly.
