1Back to top Go down   bike lift Empty bike lift Sun Sep 30, 2012 9:00 pm
kgirl
kgirl
Hi All,
Can anyone give me some advice on bike lifts? I would like to clean up my frame and respray it so I need to take it off the engine, but at this stage I do not want to pull the engine apart, so I was hoping I could leave the bulk of it together and put it on a lift for a few months.
Something like this maybe?
bike lift Img8425
2Back to top Go down   bike lift Empty Re: bike lift Sun Sep 30, 2012 9:10 pm
Should be perfect to support the engine for a few months.
Keep an eye on the bolts at the top.
I got one similar to this, the top bolts is rather short and
have a tendency to unscrew themselves after some use.
3Back to top Go down   bike lift Empty Re: bike lift Sun Sep 30, 2012 9:18 pm
Ideal thing, there is a Guy in Williamstown that sells all that sort of stuff might be worth giving him a try. I think it's Williamstown motors.
4Back to top Go down   bike lift Empty Re: bike lift Sun Sep 30, 2012 9:42 pm
kgirl
kgirl
Great thanks, I might try and get one this week, I'm keen to make a start.
5Back to top Go down   bike lift Empty Re: bike lift Mon Oct 01, 2012 7:00 am
col
col
i bought a this at repco holds 660kg
bike lift 00110
bike lift 00210
super cheap also sells something similar
1991 k100lt "the enterprise"
6Back to top Go down   bike lift Empty Re: bike lift Mon Oct 01, 2012 7:19 am
That looks like it would be good for lifting an auto gearbox into a car or similar but to leave the engine sitting on it while you work on it the handle parts could be very inconveniently in the way.
If I was going to lift the frame away from the engine then there is a good opportunity to give the injectors and air box etc a good service and clean while its easy to get at.
7Back to top Go down   bike lift Empty Re: bike lift Mon Oct 01, 2012 6:33 pm
Rick G wrote:but to leave the engine sitting on it while you work on it the handle parts could be very inconveniently in the way.
+1.
8Back to top Go down   bike lift Empty Re: bike lift Mon Oct 01, 2012 6:47 pm
dee why
dee why
Hi kgirl,
Also google Radum and check out the lifts there. They are near Melbourne Airport.
Cheers,
Dee Why
04/86 K100 VIN 0009479 Columbia Silver
9Back to top Go down   bike lift Empty Re: bike lift Mon Oct 01, 2012 7:02 pm
My lift has 'legs' deploying on the side. It gives a lot more stability to the bike.
I wouldn't feel comfortable to work only with the narrow lift.
CF
bike lift Frog15bike lift Logo2101986 k75, 1985 K100rt, 1985 K100rt/EML GT2 sidecar, 1999 K1200lt/Hannigan Astro Sport sidecar.
10Back to top Go down   bike lift Empty bike lift Mon Oct 01, 2012 7:15 pm
Hi kgirl
I have had ongoing problems with a bike lifting table. The Chinese made hydraulic piston has given out on me 3 times, each time they replaced with a new one but I cannot leave my bike up overnight for example. The lifting capacity is supposed to be 500 kg, which does work but slowly comes down.
11Back to top Go down   bike lift Empty Re: bike lift Mon Oct 01, 2012 7:45 pm
Didn`t see any Chinese bike lift Kinese10 hydraulic cylinder at the picture in the first post in this thread.
Maybe it`s time to buy new glasses............
12Back to top Go down   bike lift Empty bike lift Tue Oct 02, 2012 7:44 pm
No Mr. Inge you are quiet correct. I was just throwing in a scare in case kgirl (hello) was talked into buying a lifting table. Here in Oz it is almost impossible to buy anything not cobbled together in a hurry in China, made from low grade Aussie iron ore and cooked with low grade Aussie brown coal and skipping the quality control man at the end of the conveyor belt.
13Back to top Go down   bike lift Empty Re: bike lift Tue Oct 02, 2012 8:11 pm
RT wrote: and skipping the quality control man at the end of the conveyor belt.
It was really neceserry to remove that guy..........he did reduce the production volume to much.............
14Back to top Go down   bike lift Empty Re: bike lift Tue Oct 02, 2012 8:45 pm
Motorandy123
Motorandy123
Here's a pic of my bike up on my Chinese lift. It has a lever that pushes down to stop
it from lowering. I had my Vulcan 1500 on it once with both wheels off and came back
to find it all the way down! I use that lock now!
bike lift DSCN1132
Anyways you have to find a way to keep the engine from rolling off it. The bottom is not
very big and wiggling the frame off might tip it off the lift!
15Back to top Go down   bike lift Empty Re: bike lift Tue Oct 02, 2012 9:30 pm
Kgirl,
If you want to remove the frame to repaint it, you don't really need a lift.
What you need is to park your bike on the center stand and then put a solid block of wood under your engine. You can then lift the frame and have the power train staying on the ground with even the back wheel attached to it.
Look at my first restoration page and you will see that I didn't have a lift.
CF
16Back to top Go down   bike lift Empty Re: bike lift Wed Oct 03, 2012 1:59 am
kgirl
kgirl
Hi Everyone,
Thanks for the info/ideas, I tried to get one of the lift/stands today but they are out of stock and won't get them in for a couple of weeks so I might give Crazy Frogs idea with the wooden block a try.
That was a great link to your resto Crazy Frog.
2012 BMW F800ST & 84 BMW K100RS 0019086 Smile
17Back to top Go down   bike lift Empty Re: bike lift Wed Oct 03, 2012 3:12 am
robinm
robinm
These are the ones I use, along with an endless chain hanging from the rafters.
http://k100rt.aforumfree.com/t1242-my-special-tools
18Back to top Go down   bike lift Empty Re: bike lift Wed Oct 03, 2012 10:29 am
bike lift Statte10
19Back to top Go down   bike lift Empty Bike lift Wed Oct 03, 2012 1:46 pm
DeRodster
DeRodster
Hi Inge K,
That's a nice neat one.
Any chance you could post dimensions ?
Rod
1992 K1100LT 6455194
1943 BSA WM20
1979 Yamaha DT-175
1974 Triumph 3TA / 5TA
1974 Honda 100
1969 Honda 50
20Back to top Go down   bike lift Empty Re: bike lift Wed Oct 03, 2012 2:46 pm
Motorandy123
Motorandy123
Oh ya, I didn't think you could leave the center stand on and do it easy. I was doing the spline lube and it
has to come off for that....
21Back to top Go down   bike lift Empty Re: bike lift Thu Oct 04, 2012 1:52 am
DeRodster wrote:Any chance you could post dimensions ?
Height: 225 mm, which moves the front wheel a few mm`s above the ground.
Square: 130 x 130 mm.
22Back to top Go down   bike lift Empty Re: bike lift Thu Oct 04, 2012 3:07 pm
BIG D
BIG D
Cool
Its never safe to leave anything jacked up on Hydraulics alone, stands to take the strain is the safest bet like CF's type jack and Inge K's stand like all things there is a vast array of products out there of various quality.
Good workshop practices and safety is always the way to go
BIG D
23Back to top Go down   bike lift Empty Re: bike lift Thu Oct 04, 2012 4:01 pm
DeRodster
DeRodster
Brilliant.
Many thanks Inge.
I'll have a root around and see if I can round up some similar bits to make one up.
Rod
1943 BSA WM20
1979 Yamaha DT-175
1974 Honda 100
1969 Honda 50
24Back to top Go down   bike lift Empty Re: bike lift Sat Oct 06, 2012 2:58 pm
ReneZ
ReneZ
I use a cruiser stand for lifting the front (or the rear if without stand), like THIS, but thought about adapting something like THIS with an adapter to fit the holes in the sump where the BMW bracket is bolted.
Rene
BMW K100 - 1985 (0030029) Scotland bike lift Rain
25Back to top Go down   bike lift Empty Re: bike lift Fri Oct 26, 2012 9:57 pm
kgirl
kgirl
This might be a stupid question but I'll ask it anyway. If I make a stand similar to Crazy Frog or Inge K will I have to physically lift the bike onto the stand?
26Back to top Go down   bike lift Empty Re: bike lift Fri Oct 26, 2012 10:56 pm
1. Park the bike on the center stand.
2. Grab the top of the rim and lift the front wheel above the ground.
3. Kick a piece of wood ~3/4" thick under the front wheel.
4. Place the support under the oil pan.
5. Remove the piece of wood under the front wheel.
The support I`ve made is to be used together with the center stand.
Used alone it isn`t stable enough.
27Back to top Go down   bike lift Empty Re: bike lift Sat Oct 27, 2012 5:57 pm
kgirl
kgirl
Thanks Inge K
28Back to top Go down   bike lift Empty Re: bike lift Sat Oct 27, 2012 6:52 pm
My wooden stand works great, but I would advise to have a second person helping you when you install it.
I added an extra security to the wooden support:
When the back of the bike frame is resting on the support, I rested another piece of lumber on the frame and used C clamps to tight(sandwiched) everything together. This way, the bike is very stable.
CF
29Back to top Go down   bike lift Empty Re: bike lift Sun Oct 28, 2012 5:41 am
kgirl
kgirl
Thanks Crazy Frog
