1Back to top Go down   Lift handle Empty Lift handle Thu Oct 01, 2015 5:59 am
DaleRT
DaleRT
Had some time to tinker with the RS.
   I knew it was missing a lift handle but i now see there is no mounting block for the handle. It has had one as the welding is there. I have taken measurements of my RT if i have to have one made.
   Are such available? I cannot find any reference to one.
   Would there be an alternative lifting design?   Any ideas?
      Cheers   Dale
2Back to top Go down   Lift handle Empty Re: Lift handle Thu Oct 01, 2015 6:57 am
From realoem
http://www.realoem.com/bmw/enUS/showparts?id=0504-EUR---K589-BMW-K%20100%20RT%2084%20(0504,0505,0514)&diagId=46_1267
shows what it is like.
I have seen a hinged piece of pipe doing the same job, but looks crude compared to the original.
Perhaps one of the Krew may have a spare, though you'll have to make the attachment to the frame.
3Back to top Go down   Lift handle Empty Re: Lift handle Thu Oct 01, 2015 8:24 am
Dale,
you would not believe it, but I was at the wreckers on Saturday getting some bits for my Katana and I looked in a box of bolts.
There is a lifting handle complete with spring and two clips.
$10. its yours.
They had no idea what they sold me.
Can't help with the frame mount tho
4Back to top Go down   Lift handle Empty Re: Lift handle Thu Oct 01, 2015 8:33 am
You'll find a wreck with damaged frame at some time that you can cut the mounting off and reweld to your own.
 Lift handle Austra12    Fuel:  95 Octane
5Back to top Go down   Lift handle Empty Re: Lift handle Fri Oct 02, 2015 5:30 am
DaleRT
DaleRT
Thanks Rosskko, i will take you up on that. I'll drop down sometime [better bring your seat back too ] PM when might suit you ?
6Back to top Go down   Lift handle Empty Re: Lift handle Fri Oct 02, 2015 5:39 am
well done guys . hope it works for you Dale.
Lift handle 10_x_110
7Back to top Go down   Lift handle Empty Re: Lift handle Fri Oct 02, 2015 8:16 am
DaleRT wrote:Thanks Rosskko, i will take you up on that. I'll drop down sometime [better bring your seat back too ] PM when might suit you ?
Well, let me see.
Long weekend, so traffic will be bad for you at any time.
Saturday I am relaxing by the pool so should be free all day.
Sunday is grand final day, so I will be relaxing by the pool so should be fine all day.
Monday is a public holiday and is supposed to be quite warm, so I will be relaxing by the pool so should be fine all day.
Your call.
Or I could pop it in the post and you can buy me a beer some time. Special rates for employees?
8Back to top Go down   Lift handle Empty Re: Lift handle Mon Oct 05, 2015 12:12 am
DaleRT
DaleRT
Pop'n it in to the Post would be great - deserving of more than " a beer "   Beer drinker. Will catch -up, Dale
9Back to top Go down   Lift handle Empty Re: Lift handle Thu Oct 15, 2015 10:55 pm
Popped in post.
10Back to top Go down   Lift handle Empty Re: Lift handle Mon Oct 19, 2015 5:16 am
DaleRT
DaleRT
Thanks for that, received it today - just have to make a mounting block -
   You saved me at least a 3hr round trip, So what better way to spend it that on the RS.
   New bearings fitted to steering head, forks fitted & new discs on front wheel.
      It grinds forward  -  Thanks again - Dale
11Back to top Go down   Lift handle Empty Re: Lift handle Thu Dec 31, 2015 9:49 pm
DaleRT
DaleRT
HI  -oops- Lift handle 652573 didn't mean to shout, some of you still sleeping after last night?
   Have had success with the mounting block for the lift handle. A friend helped me out, he got a square tube & cut the frame radius, drilled hole for the pin & tang for the handle. He also made the pin for the handle.
The rest was up to me, so some cutting, welding, grinding & painting latter, its on. Looks much better than some other options [thanks again rosskko for the handle]
Lift handle 11-58211Lift handle 11-fe411
Lift handle 11-3ae17
Something else i decided to do Lift handle 12-64a10Lift handle 12-0ac11Lift handle 11-48911
At the moment an electrical issue with the Hi/Lo beam switch for the head light. It is of & pulling it apart - on the kitchen table of course [Kathy's out] -
   Trusting you are all well - Dale
