1 Timing Chain Replacement Tue Mar 29, 2011 7:04 pm
redman
Well my next project is to replace the both the timing chain (& guides) along with the water/oil pump main shaft & seals.
I'm wondering if I'll need to pull the camshafts to get the chain off. From pictures I've seen, it looks like it be possible to remove it with the tensioner & guides out of the way. Is this the case? Any other advice? I have the Clymer manual which has you remove the cams & do all kinds of measurements which I'm not going to be doing.
Thanks,
Red
Thanks,
Red
