1Back to top Go down   Noise from bevel box Empty Noise from bevel box Fri Mar 18, 2011 8:39 pm
Paul Friday
Paul Friday
What is the normal level of 'clunk' from a bevel box?
Mine makes a distinct "clack" on load reversal.
Par for the course, or time to raid the piggy bank?
Ta.
http://www.theostry.com
2Back to top Go down   Noise from bevel box Empty Re: Noise from bevel box Sat Mar 19, 2011 4:39 am
wikur
wikur
Hi Paul!
There should be no "clunks or clacs" from the rear end.
Do remove the drive shaft as is described in the download section.
It`s important to clean and regrease the splines on the driveshaft.
This is a known weak spot on the K.
Cheers,Wikur!
3Back to top Go down   Noise from bevel box Empty Re: Noise from bevel box Sat Mar 19, 2011 4:06 pm
When you drained and replaced the hypoid oil in the bevel box what did the magnet look like was there an accumulation of sludge and or gritty slivers of metal? Like Wikur above I suspect the splines but looking to eliminate all possibilities.
4Back to top Go down   Noise from bevel box Empty Re: Noise from bevel box Sat Mar 26, 2011 8:12 am
i found the pinion mooving axially in the bearings of my bevel box paul .
investigation still ongoing
