1 Section of rubber found loose in fuel tank Sun Nov 30, 2008 11:10 pm
Hi Folks,
I wonder if you can help in checking my fuel tank for water I noticed a section of what looked like fuel hose laid in the bottom of the tank I used my spring "grabber" and lifted it out. It is 60 mm long and about 12 mm in diameter and is solid not a tube with a slit along the whole length. My immediat thought was a bump stop to be slipped into the edge of some sheet metal to protect the edge or protect something from the edge. It was rubber and clearly the type of rubber that is intended for continuous fuel immersion since it was not in the least denatured by being immersed in fuel. Any comments on what it is?
