1 BEP 3.0 wiring posibility? Today at 4:38 pm
Topsis
Hello everbody, I need some electrical help with connection od Universal speedometer, link bellow.
https://www.ebay.com/itm/402780252315
So, input wires from my bike on BEP 3.0 are in the same position like on original manual instrument cluster.
I connect new speedometer with BEP 3.0 and my speedometer is up, but when I connect gears from G 1-5 and neutral its nothing hepend on speedo.
Do I need connect something with CC output on my BEP, because its write that CC is Power source indicator?
When everything was connect, on the CC output wasnt +, so do I need bypass from BAT output wich have constant Power source?
And one more question, can I connect speedo direct with Power source and masse, and BEP 3.0 only using for gear connection, speedometer and tachometer?
