1Back to top Go down   BEP 3.0 wiring posibility? Empty BEP 3.0 wiring posibility? Mon Oct 21, 2024 4:38 pm
Topsis
Topsis
Hello everbody, I need some electrical help with connection od Universal speedometer, link bellow.
https://www.ebay.com/itm/402780252315
So, input wires from my bike on BEP 3.0 are in the same position like on original manual instrument cluster.
I connect new speedometer with BEP 3.0 and my speedometer is up, but when I connect gears from G 1-5 and neutral its nothing hepend on speedo.
Do I need connect something with CC output on my BEP, because its write that CC is Power source indicator?
When everything was connect, on the CC output wasnt +, so do I need bypass from BAT output wich have constant Power source?
And one more question, can I connect speedo direct with Power source and masse, and BEP 3.0 only using for gear connection, speedometer and tachometer?
2Back to top Go down   BEP 3.0 wiring posibility? Empty Re: BEP 3.0 wiring posibility? Mon Oct 21, 2024 6:22 pm
Please see your first post (below) which was not an introduction. As agreed when you created a member name and received the confirmation from the administrator, an introduction in Member's Introduction is required before making any posts. The resources here are "free" for all members, but some commitment to the forum is required before "taking" information. Everyone who joins up does this most basic effort. Thank you for your effort in advance. If language is an issue in understanding, please use a translator.
Ako je jezik problem, upotrijebite prevoditelja jezika.
https://www.k100-forum.com/t15130-tgpi-board
