1 K75 Forks Wed Oct 23, 2013 10:08 pm
jjefferies
In my K75C -> cafe racer restoration project I found one fork tube has rust pitting deep enough to concern me and I've been looking for a replacement tube. My search has turned up several offerings on ebay but most sellers won't return my e-mail questions. Concern is that I get the correct size. My measurement of the existing fork tube gives me 41.35mm OD. The brakes are marked as "Brembo" and are single pistons. The tube has an "S" stamped in the top plug which holds the springs in and next to the hex socket screw which you fill the tubes through.
I've searched the archives but haven't found a good description of how to identify the range of offerings in tubes for the K75 other than one comment in Showa Front Fork. Which I believe was intended for other purposes:
So can anyone educate me on the differences in fork tubes for the K75 and the K100 and their interchangeability? And BTW, is a 38 mm OD fork tube worth anything? That was my first error.
thanks
J.
P.S. Rick G has a nice chart in Chart of tubes and Oil quantity that gives me the idea that there were three basic types.
Which leads me to believe I have the Brembo tubes.if your (Sachs or Brembo) fork works rough - throw it out
get a complet Showa (incl seering because of 41.0 mm instead of 41.3mm)
thanks
J.
