1Back to top Go down   The side stand mechanism. Empty The side stand mechanism. Mon Oct 07, 2024 2:39 pm
Skidmark
Skidmark
Just removed the side car body and gone to refit the center and side stand and I found a hanging linkage, it's connected the clutch as it moves slightly when I operate the clutch lever.
I'm missing the springs and not sure about this hanging underneath.
How does it re attach or should I delete it?
Mark
2Back to top Go down   The side stand mechanism. Empty Re: The side stand mechanism. Mon Oct 07, 2024 3:57 pm
Skidmark wrote:Just removed the side car body and gone to refit the center and side stand and I found a hanging linkage, it's connected the clutch as it moves slightly when I operate the clutch lever.
It's part of a safety feature. When properly adjusted, it retracts the side stand when the clutch hand lever is pulled. Free will allows you to delete it. I have mine adjusted but I usually kick up the stand without using it.
Start video at 3:58.
3Back to top Go down   The side stand mechanism. Empty Re: The side stand mechanism. Wed Oct 09, 2024 7:29 pm
Skidmark
Skidmark
Searching through a few posts it seems a k1200rs center and sidestand fill fit on the original k100 center mount, could you 100 percent confirm this and I'll go ahead and buy one.
Many thanks
4Back to top Go down   The side stand mechanism. Empty Re: The side stand mechanism. Thu Oct 10, 2024 8:51 am
Is this one of the post's you have read?
5Back to top Go down   The side stand mechanism. Empty Re: The side stand mechanism. Thu Oct 10, 2024 9:07 am
In the end I nabbed a cheap early style K100 assembly off ebay, so I've no idea what the extent of the fixerupper would have been. To summarise TWB's post;
- the K1200 mounting plate will NOT fit the K100 gearbox
- you can fit the K1200 stand to the K100 mounting plate
- BUT the K1200 stand is 20mm or so shorter than the K100 stand.
So... really you need another K100 or K1100 stand.
6Back to top Go down   The side stand mechanism. Empty Re: The side stand mechanism. Thu Oct 10, 2024 9:11 am
I have put complete K1100 stand assemblies on my K100RS RT and Sprint.
As far as I am aware but not certain the K1200 transmission uses the same stand mounts.
EDIT: Dai has confirmed they do not.!
