Taggen
Taggen
Hi! After a long winters sleep (indoors) was it time to start the bike. When i connected the battery (brand new one) the warninglights came on as if i turned the ignition key to ”on” and the fuel pump started up (goes on and on). No sparks on the sparkplugs. OK, so I purchased a ignitionlock, convinced that the problem was in the lock, but no, still the same problem. I disconnected the relays one by one - no differens,  Iv’e tested all the fuses, they are all allright. I have loosen all groundpoints and cleand them , but no differens whatsoever. Is anybody out there familiar with this problem?? ( when i turn the key to ”on” I’ve notised a slight encrease in the lights from warninglights on the panel)
Put the year and model of your motorcycle in the Signature section within the Profile tab to make the information show up in every post you make. Electronics and parts in models can vary from year to year.
Taggen
Taggen
Bmw K1100 LT year 1995
BMW K1100 LT 1995
4Back to top Go down   Warning lights start up when battery connects Empty Warning lights Sun Sep 22, 2024 5:40 pm
daveyson
daveyson
I keep telling myself not to post on K1100 threads, which I'm not familiar with, but here she goes.
I'm assuming you've ridden many trouble free kilometres on this bike before the  problem started. I'm assuming when you connected the battery, the pump came on, but the engine wasn't cranking. I'm assuming you had multiple attempts of connecting the battery with the same result.
My first thought was there is a short on the positive side which is bypassing the ignition switch. Another thought was has it been stored on the side stand with the handlebar turned hard right, and does the problem disappear when turned the other way, or when straight?
Which lights came on?
The cluster lights came on, they shouldn't, seems to point to a short between the cluster and the ignition switch, or a wire of the same colour.
Another problem is the fuel pump running continuously, it shouldn't. If there were multiple battery connection attempts in a short time frame, the on-off, on-off, results of multiple sparks with contacts could make the tiny fuel relay contacts get hot and sticky. Check if there is continuity between pins 30 and 87, there shouldn't be, if there is, give it a good tap, and try again.
Leave the fuel relay out and the headlight off while checking for a short. You can make a few checks to help isolate the problem. Is there a faint click from the relief relay with the battery connected, there shouldn't be. Do the warning lights turn off with the fuse for the green/yellow, green/black wires removed, they should. Do the lights turn off with the kill switch turned off, they should. This could isolate the problem to a particular wire colour code. Then use a test light to further isolate the problem, say from the cluster back towards the battery, one step at a time.
 ~120,000 km
