1 Acewell CA080 speedo unstable MPH Tue Sep 03, 2024 1:10 pm
Glyn Ruth
Hi All,
I've been spending hours reading the Acewell posts here without finding the answer to my problem. I've fitted an Acewell CA080 which all appears to work fine. I fitted a NPN hall effect speedo sensor in the rear drive unit giving 6 pulses per revolution and built the Neutral light circuit as per the instructions herein. All the warning lights work fine as does the fuel and temp guages and spinning the rear wheel by hand gives me a speedo reading. The problem only occurs when the engine is running. Whilst at rest on the stand, I start the engine and the speedo reading is all over the place without the rear wheel turning. I don't think the RPM is that stable either but when revving the engine the speedo can read up to 34 mph intermittantly and then go down to zero before jumping up again. I have the R/C circuit in the speedo sensor wire but nothing in the RPM (Acewell) yellow wire. Does anybody have any ideas what could be causing this and am I correct in thinking that I get 1 pulse per 2 revolutions of the engine for the tacho?
