1Back to top Go down   K100RT intro Empty K100RT intro Sat 14 Sep 2024, 14:31
agbikeadv
agbikeadv
Hi,
Purchased an 87 K100RT a few months back which had sat idle for unknown years and I am finally getting around to getting it back on the road. Is Ex NSW Police bike and was used at Queanbeyan. 99k on the odometer.
Thankyou
Tony
Last edited by Two Wheels Better on Sat 19 Oct 2024, 07:20; edited 3 times in total (Reason for editing : Wrong intro)
2Back to top Go down   K100RT intro Empty Re: K100RT intro Sat 14 Sep 2024, 17:08
The fuel pump will only keep running when engine revs are above 711rpm and when the start button is pressed, it will then continue to run for 1.5 seconds after the start button is released if the engine has not fired.
3Back to top Go down   K100RT intro Empty Re: K100RT intro Sun 15 Sep 2024, 05:38
WelKome. It makes sense to only introduce yourself here, then ask questions in the appropriate "troubleshooting" section.
4Back to top Go down   K100RT intro Empty Re: K100RT intro Fri 04 Oct 2024, 06:07
Bernie_K100
Bernie_K100
Hi Rick,
K100RT intro 177912 to our community!
Bernie
5Back to top Go down   K100RT intro Empty Re: K100RT intro Tue 08 Oct 2024, 17:11
hi Tony
im just up the road in Glen Innes , if you need a hand with something
there are a few of us up this way in guyra  etc
regards
charlie
6Back to top Go down   K100RT intro Empty Re: K100RT intro Wed 09 Oct 2024, 02:50
K100RT intro 177912
7Back to top Go down   K100RT intro Empty Re: K100RT intro Sat 19 Oct 2024, 02:18
Porto
Porto
Hi Tony. I am in Peak View just a couple of hours away. Let me know if you need some help.
8Back to top Go down   K100RT intro Empty Re: K100RT intro Sat 19 Oct 2024, 07:02
bad boy
bad boy
hello Tony
K100RT intro 177912
Cheerz, David
K100RT intro 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
