Having temporarily run out of stuff to do on the 850-T3 and the 1100-T3 (waiting for parts from Italy... waiting for parts from Italy... waiting for parts from Italy... you get the picture
) I've got a bit more time to spend on this. In truth, slapping the laptop lid shut at 16.15 to finish work and then spending two - three hours in the garage is a good move for my mental sanity. The Covid-19 pointer has moved across the scale from the 'if we get it' side more towards the 'when we get it' side because there's now four confirmed infections on Elizabeth's ward and not enough PPE. So building bikes is what I do to switch off from it.
As I said a few entries ago, I intend to replace all the brake hoses. The easy point to start was the rear caliper; I'd already had the battery tray off and freed up the reservoir, so it was just a few bolts and the wheel in the way. I've always thought that the way the rear reservoir is mounted is not far short of bloody stupid so, like I did with Brick2, I'll be making some form of bracket that does NOT require me to remove the battery, FICU and battery tray just to unscrew the bloody reservoir.
Oh dear. Definately the worst case of aluminium spalling I've ever seen on a brick.
http://simpilot.net/~sc/brick3/12b.jpgJames Sherlock and Motorworks want £50 for one. Someone on ebay wanted £19 for a really good one, so I had it. I completely failed to spot that someone else had put up both footpeg hangers, rear master cylinder, brake pedal and all the foot pegs for £20. Shit.
So I had that too.
The rear caliper would not come apart. No way, José. I applied a lot of heat; one bolt came out but the other just snapped. An M12, fer fecks sake!!! Just snapped! I clampd the stub in the vice but it wasn't going to move. I left it overnight soaking in Kroil, but it made not a blind bit of difference. Okay... add that to the parts required list. A perusal of ebay, James Sherlock and Motorworks showed them all at about £50. Gonna havta wait till next month.
The front calipers fared slightly better. They both needed copious amounts of heat but... yes... I managed to sheer another bolt. This time I tried to drill it out, but after I reached 6.9mm and failed to punch out the remains of the bolt, I gave up. I just so happened to have a spare side of the caliper living in the caliper drawer, so no problem this time.
http://simpilot.net/~sc/brick3/13b.jpgThe one in the vice is about to get the rear bolt broken - spot the grey overspray. The one on the bench has been split and refurbished. On the right is the remains of the rear caliper.
