1 cooling fan fuse location and fan testing Tue Aug 21, 2012 5:29 pm
tom_k75c
When I ran the engine after rebuilding the oil/water pump, I don't think I heard the fan come on when the engine got warm. I want to check the fuse, but I can't find a fusebox diagram in the Clymer manual (the fuse box cover that may have had a diagram is missing). Can someone tell me or show me which fuse goes to the fan?
I also want to check whether the fan works. The Clymer manual says (on page 324) "Remove the clip and disconnect the electrical connector from the switch, then place a jumper wire between the two electrical terminals in the electrical connector. Turn the ignition switch on and the fan should start running."
I see a wire (that I think is the clip) going around the square connector, but I don't want to damage it by removing it incorrectly. How do you "remove the clip"?
Thanks, Tom
