1 Steering Locks Tue Aug 27, 2024 3:42 am
jjefferies
"Steering Lock" defined. It is that lock on the left side steering tube that when working properly will lock the forks. Used as a theft deterrent.
Ok, I do acknowledge that 1) because of placement is difficult to use on some models 2.) Can easily be broken simply by whipping the handle bars back and forth {this was told to me} 3.) gets in the way.
Still I am trying to get the bike all together with all the locks working and that requires that I pull this lock and work it. So is the lock cylinder held in place simply by the cover? The plastic cover is held on by one pin which I am told is removed with a chisel or other sharp instrument and then pulled after the cover is pulled off. A sharp set of pliers was mentioned. But once the cover is removed does the cylinder/tumbler just pull out or do you have to have the appropriate key and then rotate it?
So the question is will the tumbler/cylinder pull out without the key or missing the key do you need to drill the tumbler/cylinder out? Inquiring minds and all that!
