2 Re: Gear shifter problem (BSK rearset) Sat Sep 08, 2018 6:04 pm
I would suggest a call to BSK. They are good at responding to queries.
Have you attempted to adjust the 'turnbuckle' mechanism in and out to keep the shift lever in a steady state position? I'm sure it needs to have a certain tension to stay aligned - it appears from your pictures, but not your description, to be slipping beyond the ideal position.
Do you see the alignment mark on the end of the splined shaft on your gearbox? That generally has to be aligned with the gap in the shift lever. Go to BSK's website and look at how they have mounted the lever of all of the race bikes. It is positioned at nearly twelve o'clock high. That may be yer problem.
"Politics is the entertainment division of the military industrial complex."
- Frank Zappa
1977 R75/7-100, '93 K11/K12 Big Block, '93 K1100RS, '95 R100 Mystic, '96 K1100RS, 2 x '98 K1200RS, '06 K1200R & '09 K1300GT
3 Re: Gear shifter problem (BSK rearset) Sat Sep 08, 2018 6:36 pm
TWB's right (as usual ) The gearbox-thingy-bit has to be perpendicular to the ground (i.e. pointing straight up) to get the gearbox shift mechanism to work correctly. As it is at the moment, you're only getting a partial shift in the box and the dogs are not engaging correctly.
4 Re: Gear shifter problem (BSK rearset) Tue Sep 11, 2018 12:17 pm
Jakey
Thanks I will look into it later this week an post a update I saw someone has the `turnbuckle`oppsoite of mine. (at the bottom instead of the top like mine). Don`t know if it just the angle or if it`s the correct way to mount it.
5 Re: Gear shifter problem (BSK rearset) Tue Sep 11, 2018 12:55 pm
Start with the basics.
- Frank Zappa
6 Re: Gear shifter problem (BSK rearset) Sun Sep 16, 2018 4:52 pm
Jakey
Thanks for the help, that was the problem Works fine now.
7 Re: Gear shifter problem (BSK rearset) Sun Sep 16, 2018 4:55 pm
Oh, good. Very glad it was easy to sort.
- Frank Zappa
8 Re: Gear shifter problem (BSK rearset) Sun Sep 01, 2024 12:42 pm
Garfoid79
How did you fix this as I am having the same issues?Jakey wrote:Thanks for the help, that was the problem Works fine now.
9 Re: Gear shifter problem (BSK rearset) Sun Sep 01, 2024 8:00 pm
The four axles need to form a parallelogram. If the linking rod is too short, you can't shift properly.
That fills our fairest day.
K100-forum.com » Technical, repair and troubleshooting » Frame, fairing and wheels » Gear shifter problem (BSK rearset)
Similar topics
