1 Low idle speed Sun Jul 07, 2024 5:43 pm
taube
My bike will start and run only with the "choke" open about halfway, raising the idle to 1000 rpm. If the choke is closed the engine stalls right away. What could the cause be?
Thus far I have replaced fuel injectors, the fuel filter, all fuel lines (in-tank, and the ones at the fuel rail and the FPR), the air filter, and the "z-tube" crankcase breather hose.
I re-fitted the throttle bodies too. I wonder if that job mal-adjusted something? I had a hard time un-fitting and re-fitting the choke cable nipple. Not sure if that's likely. Thoughts?
taube
taube
Restoration project: 1988 BMW K100RS
Currently riding: 2019 Honda CBR300R
