1Back to top Go down   Lack of power above 3500RPM... Empty Lack of power above 3500RPM... Fri Jul 12, 2024 6:53 pm
HZolio
HZolio
Hi there!
So, i need your help!
The bike is my 1992 K100RS 16V, with 152000km. Starts, idles and rides flawless, but (more noticeable on 5th gear), it doesn't make more than 3500rpm easily... she can rise downhill, but at a cost!
I already adjusted CO and ignition, balanced those ITB, new plugs and "usable" plug wires. ALL fluids changed, refrigeration gremlins sorted, and air filter is new! Also changed the shot steering bearings and serviced the forks, new seals on the front brake pump, flushed all the DOT4 (ABS fully working Very Happy ), all of this is obviously not the culprit but FYI...
On 2 months reading the forum i learned: the tank is mirror clean, the fuel filter (IDK) looks new, as the pump also!
I noticed, when adjusting the CO, the potentiometer was VERY sensitive. It is normal?
Where do i start? New fuel filter? Or...
Any help would be appreciated!
May thanks
HZolio
'92 K100RS 16V
'86 R65
'10 R1200GSA
...and too many to list...
2Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Fri Jul 12, 2024 7:11 pm
You can test the fuel filter by taking it out and attempting to blow through it.
3Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Fri Jul 12, 2024 7:50 pm
Jordan53
Jordan53
On a bike with carburettor, I found a fuel filter that could not be blown through - but looked pristine.
I now don't use the pesky things on such bikes. The float bowl is an effective sediment trap.
Is it reasonable to leave out the filter with fuel injected engines?
1989 K100 RS
VIN: xxx0149621
4Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Fri Jul 12, 2024 8:37 pm
Not at all reasonable to leave the fuel filter out it is very necessary as any particle larger than 4 micron can cause an injector to seize.
I routinely replace the fuel filter each year and have cut a few open to see what has been caught, you would be very supprized what comes out of a fuel pump at a service station.
5Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Fri Jul 12, 2024 10:25 pm
They can also clog due to age because the filter fibers can swell, especially if the gas has water in it absorbed by ethanol.
6Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Sat Jul 13, 2024 9:32 am
Bricklayer
Bricklayer
I had a similar loss over power as the engine RPM climbed over 3k. It was a bugger to troubleshoot. A fuel line inside the tank had a small crack that only leaked either from higher vibration or vacuum drop causing FPR to increase pressure (or both working together to infuriate me).
I was at wits end until I open the fuel tank lid and viewed inside with a flashlight/torch and worked the throttle.
If one is changing the fuel filter and are unsure of the fuel line hose age, might as well replace those whilst in there.
https://anthonymrugacz.net/
7Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Sat Jul 13, 2024 12:52 pm
HZolio wrote:The bike is my 1992 K100RS 16V
I'm curious, do you have an exhaust gas analyser stuffed up the exhaust tailpipe that allows you to "see" the changes you make to the potentiometre when turning it? Yes, they are very sensitive. A screwdriver blade width can make a big difference. Also, it would be the very last thing to do after all other proper tuning and maintenance requirements are met.
8Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Sat Jul 13, 2024 3:42 pm
HZolio
HZolio
Yes, of couse: first with my trusty Bosch on my own garage, but then, as i only noticed few changes, i took the K100 to the work, as i'm the technician on MB Classic Center in Sintra, and "my" gas analyser there is checked by the government at least, one time/year... but, with no great sucess...
HZolio
'92 K100RS 16V
'86 R65
'10 R1200GSA
9Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Sat Jul 13, 2024 3:46 pm
HZolio
HZolio
duck wrote:You can test the fuel filter by taking it out and attempting to blow through it.
Unfortunately i'm near the end of my vacations far away from the K100, but when i take it off, i will notice you!
Thanks!   Cool
HZolio
'92 K100RS 16V
'86 R65
'10 R1200GSA
10Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Sat Jul 13, 2024 3:51 pm
HZolio
HZolio
Jordan53 wrote:On a bike with carburettor, I found a fuel filter that could not be blown through - but looked pristine.
In my other carburated bikes, i also do not recommend one fuelfilter, as i can clean one carb bowl and gigleurs easily, but here... NO!
Thanks!
HZolio
'92 K100RS 16V
'86 R65
'10 R1200GSA
11Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Sat Jul 13, 2024 3:55 pm
HZolio
HZolio
Rick G wrote:Not at all reasonable to leave the fuel filter out it is very necessary as any particle larger than 4 micron can cause an injector to seize.
Next task to do!!!
Thanks!!!
HZolio
'92 K100RS 16V
'86 R65
'10 R1200GSA
12Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Mon Jul 15, 2024 11:42 am
Definitely change the fuel filter.  I had a problem with one.  The worst part was that it was right on the edge of not enough flow so that sometimes the engine worked okay, and sometimes it lost power.
It's a good idea to change the filter every couple years, because even if it doesn't block enough flow to hurt performance, it can make the fuel pump work harder and that can't be good for the fuel pump.
13Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Mon Jul 15, 2024 1:58 pm
As said before, the fuelfilter.
But besides that, possible that the TPS (not Switch, but Sensor) needs to re-learn his tricks.
I have a file in my cloud on howto, download and have fun Smile
https://mega.nz/file/Guw0GBDC#iy63G00X3NE_ZfwgNYlvUXYmxVcKvXJkk-oxj8Ah9Eg
Lack of power above 3500RPM... Eu-log10  K1100RS/LT - R1200RT - R1100RS - Cagiva SST 350 Ala Verde - K75LT project - K75 Schurgers - K75S - K1100RS - K75RT - K75C
14Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Tue Jul 16, 2024 3:48 pm
HZolio
HZolio
Hi all,
Yes, you were right! 2003 fuel fiter, almost blocked on the blow test!
Lack of power above 3500RPM... Img_3810
Yesterday i changed it for a new one and today the bike rode perfectly!
Thanks for the tips!
HZolio
'92 K100RS 16V
'86 R65
'10 R1200GSA
15Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Tue Jul 16, 2024 4:45 pm
We love a definitive fix!  cheers
16Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Tue Jul 16, 2024 6:01 pm
HZolio
HZolio
Two Wheels Better wrote:We love a definitive fix!  cheers
Me too!  Cool
Now the fun part: i didn't have the time yet to purchase a new fuel filter, but i need to try this. So at the work (MB) i have laiyng around a bunch of used (new??? Cool) f filters from the SLR McLaren... the maintenance schedule DEMANDS to change them, even if the SLR like in most cases, have runned for 500km... in 2 years! And yes, they are also inside the tank, and you have to remove the tanks from the car (2 of them) to change those filters...  So i keep them for testing purposes and yes, my K100 is using now one of those!!!
McLaren filter made the K100 pass 180km/h today!!!!!!!    Very Happy
HZolio
'92 K100RS 16V
'86 R65
'10 R1200GSA
17Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Tue Jul 16, 2024 7:38 pm
Good to hear that you found and corrected the problem.
Even better that it was an inexpensive fix.
18Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Wed Jul 17, 2024 5:52 am
HZolio wrote:McLaren filter made the K100 pass 180km/h today!!!!!!!    Very Happy
idea2
19Back to top Go down   Lack of power above 3500RPM... Empty Re: Lack of power above 3500RPM... Wed Jul 17, 2024 12:29 pm
Never mind the date on the fuelfilters.
There is a lot of NOS, even when you buy a new one at the dealer these days, big chance it's 20 or more years old.
