1Back to top Go down   Hybrid Project in Colorado Empty Hybrid Project in Colorado Sat Jun 29, 2024 11:29 pm
deucydeuce
deucydeuce
Hello all, I've come across this forum a time or two so decided to join and say hi.  Currently have an 85 K100 project and a good running 93 K1100.  The K100 was picked up as a non runner with an oil leak.  Got her running and have decided to a full custom rebuild.  Currently working on swapping an R1200C swing arm and final drive before doing frame work and engine rebuild.  I know there are some purists that won't appreciate the work, but I'll do my best to post some pictures for those that do.  Cheers, and thanks for the help in the past.
https://servimg.com/view/20570712/7
https://i.servimg.com/u/f63/20/57/07/12/img_5817.jpg
2Back to top Go down   Hybrid Project in Colorado Empty Re: Hybrid Project in Colorado Sun Jun 30, 2024 8:10 am
Hybrid Project in Colorado 177912
3Back to top Go down   Hybrid Project in Colorado Empty Re: Hybrid Project in Colorado Sun Jun 30, 2024 8:54 am
I used to consider this solution before...
How is the rear wheel aligment with the front?
That fills our fairest day.
4Back to top Go down   Hybrid Project in Colorado Empty Re: Hybrid Project in Colorado Sun Jun 30, 2024 11:22 am
bad boy
bad boy
hello deucydeuce
Cheerz, David
Hybrid Project in Colorado 9438-010
K75 fork, K100 monolever, headlight, indicators, K1100RS gearbox, K1200RS 589 instrument cluster, engine, rear wheel
5Back to top Go down   Hybrid Project in Colorado Empty Re: Hybrid Project in Colorado Sun Jun 30, 2024 2:38 pm
deucydeuce
deucydeuce
jbt wrote:I usé to consider this solution before.
.How is the rear wheel aligment with the front?
The rear is off center by about 5mm, I'm planning on adding a spacer.  The real hurdle is the u-joint, I'm swapping the flange yoke from the K100 over to the driveshaft of the 1200 but they use different size u-joints.  Think I found a solution, but won't know for sure until it arrives.
6Back to top Go down   Hybrid Project in Colorado Empty Re: Hybrid Project in Colorado Tue Aug 13, 2024 6:03 am
Bernie_K100
Bernie_K100
Hi,
Hybrid Project in Colorado 177912 to our community!
Bernie
