1Back to top Go down   Intermittent Speedo Empty Intermittent Speedo Mon Jun 03, 2024 7:47 am
tedinniebos
tedinniebos
The speedo on my '86 K100 RS works very randomly. If it decides to work at the beginning of a ride, it normally keeps working, but about 3 out of 4 times it doesn't work at all during a ride. I've checked the connections - all seems fine. Any suggestions on how to troubleshoot/what to look for?
Thanks in advance!
Ted
'86 K100 RS
2Back to top Go down   Intermittent Speedo Empty Re: Intermittent Speedo Mon Jun 03, 2024 9:07 am
The speedo sensor is in the rear drive remove it and clean the face that usually works. You can often check the workings by holding a electric mains soldering iron close to the drive and it will induce a pulsing into the sensor. Not real sure but from memory 50hz is 36mph.
3Back to top Go down   Intermittent Speedo Empty Re: Intermittent Speedo Mon Jun 03, 2024 9:53 am
tedinniebos
tedinniebos
Thanks Rick G! I'll try that tonight, and post feedback.
'86 K100 RS
4Back to top Go down   Intermittent Speedo Empty Re: Intermittent Speedo Tue Oct 15, 2024 1:18 pm
tedinniebos
tedinniebos
So after this issue resolving itself when I switched out the lunchbox to a BEP 3.0 / cheepo (eBay) speedo, everything worked beautifully for about a month, then the intermittent speedo gremlin returned. I'm considering replacing the entire wire loom from the sensor all the way to the BEP, but that does seem a bit extreme. Any other suggestions before I begin surgery?
'86 K100 RS
