1Back to top Go down   snapped bolt in crankcase cover Empty snapped bolt in crankcase cover Tue May 21, 2024 4:29 am
mmgee123
mmgee123
I have a 1988 bmw k100 and i was putting my crankcase cover back on after replacing my starter and torqued a bolt down to one too many foot pounds and it snapped off inside my block (i need to invest in a torque wrench). does anyone know anywhere i could find a new bolt (preferably a store but i’ll order if i have to) and how i should remove such a small bolt? it’s the 10mm with the gasket
2Back to top Go down   snapped bolt in crankcase cover Empty Re: snapped bolt in crankcase cover Tue May 21, 2024 10:07 am
I dont understand about the crankcase cover, it does not need to come off to replace the starter.
Those bolts need very low torque.
A guess is www.motorworks.co.uk or www.tills.de but either way you should renew all the bolt gaskets and the o ring gasket on that cover as yours are likely to be hard.
3Back to top Go down   snapped bolt in crankcase cover Empty Re: snapped bolt in crankcase cover Tue May 21, 2024 12:09 pm
MaxBMW in New Hampshire will get your parts to you before you know it. Pandora in Chattanooga might have it but they don't make it as easy to find out.
The o-ring in the diagram doesn't even have an entry in the K100 2-valve parts list. If it was still needed but unavailable, the o-ring (6) usually would be in the parts list with NLA (No Longer Available) in its price column. The K75 has the same bolt, same bushing and same configuration of crankshaft cover as your 2-valve K100 but the o-ring isn't in the drawing. Maybe BMW discovered it wasn't need at all. Anyway, that's for you to find out. Smile  You could likely get a Viton o-ring at a local auto parts store, if you had the old ring or dimensions of it.
snapped bolt in crankcase cover Cranca10
snapped bolt in crankcase cover Crankc10
snapped bolt in crankcase cover Crankc11
4Back to top Go down   snapped bolt in crankcase cover Empty Re: snapped bolt in crankcase cover Tue May 21, 2024 3:06 pm
How to remove broken bolts: EZ-out
https://www.google.com/search?q=ez-out
5Back to top Go down   snapped bolt in crankcase cover Empty Re: snapped bolt in crankcase cover Tue May 21, 2024 6:51 pm
mmgee123
mmgee123
i found some on ebay just gotta wait for them to come in and i bought that kit! was just hoping to find something i didn’t have to buy online im itching to ride, thanks guys🙏🏽
1988 k100
6Back to top Go down   snapped bolt in crankcase cover Empty Re: snapped bolt in crankcase cover Tue May 21, 2024 8:46 pm
Hardware stores generally have EZ-outs in stock at stores.
7Back to top Go down   snapped bolt in crankcase cover Empty Re: snapped bolt in crankcase cover Wed May 29, 2024 1:06 am
mmgee123
mmgee123
92KK 84WW Olaf wrote:I dont understand about the crankcase cover, it does not need to come off to replace the starter.
i thought they needed to be torqued high so i was really cranking on it, and i had to pull it off to lube the gears because it was stuck
8Back to top Go down   snapped bolt in crankcase cover Empty Re: snapped bolt in crankcase cover Wed May 29, 2024 2:05 am
A 6mm screw, with a purpose of basically sealing the cover along with its mates, and going into an aluminium casing, wouldnt need ft/lbs. More like inch/lbs.
