1 Faultering after warming up Wed May 15, 2024 6:25 pm
davemadsen
1987 K100RT.
The bike run flawlessly for maybe 2 minutes and then develops a very light miss that is most noticeable coming off idle. It is similar to an air leak although I have sprayed starting fluid around the boots and hoses with no change in engine speed.
The following have been checked:
Valve clearances
FPR (35 psi at the fuel rail)
Spark plugs (strong spark)
Spark plug wires
Temperature sensor resistance
What other factors should I be assessing?
Dave
Valve clearances
Spark plug wires
Dave
Dave
