1 Suzuki switches on a K1100 Sat Nov 11, 2023 6:27 am
Glyn
Hi all, I'm working on my K1100 which I bought with many parts missing and getting it back together gradually. The original clutch and front brake systems were either missing or badly damaged and the controls on both sides beyond reasonable repair. So it got interesting when I bought a Suzuki GSXR loom including levers and controls for a mere £20. All went well apart from having to buy a new 20mm master cylinder as the GSXR has only a 14mm piston. All of the electrical parts worked after I installed them except the flashers which won't turn off (which I expected as the Suzy item is latching and not momentary). Will I have to fit a Suzuki flasher unit and discard the BMW panel or can the BMW parts be modified for use? It does complicate things a little because the BMW switches to earth whereas the Suzuki switches the +12volts. I remember reading something on this from Dai but can't find it again.
