1Back to top Go down   K100 RT crush washers and o-rings Empty K100 RT crush washers and o-rings Fri Nov 17, 2023 5:30 pm
davidaryun
davidaryun
I saw a list of all of the crush washers and o-rings necessary for changing fluids and can't find it again. Any Help?
Bricklayer
Bricklayer
Alternate solution:
One can purchase a kit with aluminum crush washer/gaskets in a kit of 470 which comes out to less than 4 cents a piece on Amazon. After 5 years of using these I haven't had a leak yet.  ;-)
After engine, transmission, fork, rear drive, et al. fluid changes, all the sizes have been in the kit.
Here's a link to them on Amazon
K100 RT crush washers and o-rings Cursh-10
https://anthonymrugacz.net/
3Back to top Go down   K100 RT crush washers and o-rings Empty Re: K100 RT crush washers and o-rings Fri Nov 17, 2023 10:02 pm
Post moved to Parts Substitution.
That looks like a little bit of everything for R, K, F & G bikes. Goodonya!
