My K1100 experience if you do not mind...
As concerns the total HT line resistance, I mean between coil and spark plug central electrode, it is over 140 000 km that I ride with 4 lines of 7 kohm each. No problem at all except that:
a) the engine does not heat as much as before, as most K1100s with 12 kohm lines are famous for doing. This is probably the result of better sparks.
b) the engine is definitely smoother
c) the fuel consumption is probably lower. But as the engine is more pleasant, I have more tendency to play with it.... For sure it does not consume more. For many years I was - because there is another point to follow - around an average of 5 to 5.2 liters per 100 km, riding around 4000 rpm. Before changing those lines I was rather around 5.4.But the synchro was possibly not ideal then.
The removal of 5kohm in the HT line can be made two ways:
a) using non resistive spark plugs whilst keeping the original BMW wires (wires which have 2k on the coil side and 5k on the plug cover side)
b) keeping the resistive spark plugs (5 kohm) and changing the wires for less resistive ones. That is the solution I preferred because most "modern" spark plugs are resistive, and as it gives the occasion of renewing the HT wires, which are surely not eternal. I purchased mine in UK, in a company called BSK Speedworks, which is obviously in love with our Ks.
For a long time I used NGK spark plugs, mainly DR7EA9, which come without the nipple. So for years I dismantled the old nipples and fitted them on the new plugs. Aluminium against steel. Recently I was faced to ignition problems. I noticed that when I dismantled my spark plugs their nipples were loose. I fitted new NGK spark plugs, with nipples well tightened, The problems were solved... for 2000 km. And again the nipples were loose.
I therefore decided to get rid of those spark plugs needing an apparently wearing accessory to fit the HT lines. In the technical manual it is stated that the engine should be fitted with spark plugs with a gap of 0.5 to .0.7mm. In Bosch it is the XR5DC plugs which are suggested. Those plugs have nipples solid with the central electrode. Impossible to get loose.
Exactly what I wish.
Looking for XR5DC spark plugs, I found two models of them. Same name but not same specs.... One is the XR5DC referenced 0.242.145.500. The other one is the XR5DC referenced 0.242.145.516. Only one is convenient: the one with the reference ending by 500. That one has a gap of 0.6mm. The other one has a gap of 0.9mm, i.e. 28 to 80% more than stipulated by the engine designer, who has probably good reasons for asking for a gap of 0.5 to 0.7 mm. Probably related to the coils behaviour.
I installed those XR5DC with a reference ending by 500 and... my bike now works like in a dream. So far I emptied 3 tanks and my fuel consumption has been between 4.7 and 4.9 litres per 100 km.
As I am the kind of person who easily believes what experts say, I took as granted that the NGK DR7EA were excellent plugs for our K1100s and I fitted them exactly as they came off their box. I.e. with a 0.9 mm gap... I just checked that both electrodes were parallel to each other, as their designer has designed them for a uniform sparks distribution. In my mind, when you change a gap you change the electrodes geometry. The correct gap is then just towards one edge of the central electrode, which implies that the spark is always at the same narrowest place. That should imply faster wear. This is less true for spark plus with a very thin central electrode. These do not appear suitable for the Ks anyway. They are told to be eventually convenient for the 2 valve Ks, but as they are necessariy resistive, there is something strange...
If Bosch make two types of XR5DC it is probably because a XR5DC with a 0.9 mm gap reduced to 0.6 does not work as well as a true 0.6mm gaped one.
To be complete and fair, I must confess that in addition to changing the spark plugs for some with the proper gap, I also changed the HT lines for new ones. One set costs the price of one cheap tyre and I estimate that after 10 years they have the right to retire.
This is just my experience. I surely do not mean that it is the only good one!
